A Workgroup Bridge (WGB) is a small stand-alone unit that can provide a wireless infrastructure connection for Ethernet-enabled devices. Devices that do not have a wireless client adapter in order to connect to the wireless network can be connected to the WGB through the Ethernet port. The WGB associates to the root AP through the wireless interface. In this way, wired clients get access to the wireless network. The WGB connects to a hub through a standard Ethernet port that uses a 10-Base-T connector.
Many of us thought, the clients of a WGB had to be in the same vlan as what had been assigned to the SSID that the WGB used to associate to the root AP. This is not the case and you can put them into another VLAN quite easily, you just need to remember some rules:
1. WGB SSID it connects to root one must be native VLAN
2. ROOT AP must have 'infrastructure-client' configured on DotRadio to treat clients as infrastructure devices
Cut-down configuration
only including the necessary parts for multiple VLANs.
ROOT AP:
dot11 ssid WGB
vlan 10
int dot 1
encryption vlan 10 mode cipher wep128 <<-- this is optional
ssid WGB
station-role root
int dot 1.10
encapsulation dot1q 10 native
int dot 1.20
encapsulation dot1q 20
bridge 2
int fast 0.10
int fast 0.20
bridge 2
end
WGB AP: with dot1q capable switch connected:
dot11 ssid WGB
vlan 10
int dot 1
encryption vlan 10 mode cipher wep128 <<-- again optional
ssid WGB
station-role WGB
int dot 1.10
int dot 1.20
bridge 2
int fast 0.10
int fast 0.20
bridge 2
end
WGB Switch with Trunking:
interface GigabitEthernet1/0/1
switchport
switchport encapsulation dot1q
switchport trunk native vlan 10
switchport mode trunk
switchport allowed vlan 10,20
-or-
WGB AP: with a client directly connected to FastEthernet or non-trunking switch
dot11 ssid WGB
vlan 10
int dot 1
ssid WGB
station-role WGB
int dot 1.10
int dot 1.20
bridge 2
int fast 0.10
int fast 0.20
bridge 2
workgroup-bridge client-vlan 20 <<---- this pushes all traffic from FastEthernet into VLAN20
end
WGB Switch without trunking:
switchport
switchport access vlan 20
switchport mode access
spanning-tree portfast
I didn't think the command 'workgroup-bridge client-vlan 20' actually worked, but to my surprise when I configured it as above I was able to successfully ping from a client directly connected to the FastEth on the WGB with no trunking enabled.
Reference
Cisco Aironet Workgroup Bridge FAQ
Access Point as a Workgroup Bridge Configuration Example
