10-24-2011 11:25 AM - edited 11-18-2020 02:55 AM
Wireless sniffing on the Mac works well, as Mac OS X has built in tools to capture a wireless trace. However, depending on what versions of OS X you are running, the commands may vary. This document covers OS X 10.6 through 10.8.
If you are running OS X 10.6 (Snow Leopard) or above, then you can easily use the command line utility “airportd”. Use the following steps:
“sudo /usr/libexec/airportd en1 sniff 11”
Some things to note:
The airport utility is is not a sniffer program; however, it can provide interesting information about the wireless LAN. Also, it has the ability to set the default wireless channel - which is crucial for sniffer programs (tcpdump, Wireshark) that are themselves unable to set the channel
Note: because the path to the airport utility is so ugly, it may be a good idea to set a symbolic link to it from a directory in the path, e.g.
# sudo ln -s /System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport /usr/sbin/airport
set the wireless channel
# sudo /System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport --channel=48
dump out info on the SSIDs/BSSIDs seen:
# sudo /System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport -s
SSID BSSID RSSI CHANNEL HT CC SECURITY (auth/unicast/group)
Test 00:24:97:89:cb:41 -53 11 Y -- WPA(PSK/TKIP/TKIP) WPA2(PSK/AES/TKIP)
Test2 00:24:97:89:cb:40 -53 11 N -- WPA(PSK/TKIP/TKIP)
Guest 00:22:75:e6:73:df -64 6,-1 Y -- WPA(PSK/AES,TKIP/TKIP) WPA2(PSK/AES,TKIP/TKIP)
detailed information on the current association:
# sudo /System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport –I
agrCtlRSSI: -54
agrExtRSSI: 0
agrCtlNoise: -89
agrExtNoise: 0
state: running
op mode: station
lastTxRate: 300
maxRate: 300
lastAssocStatus: 0
802.11 auth: open
link auth: wpa2-psk
BSSID: 0:24:97:95:47:60
SSID: GuestNet
MCS: 15
channel: 36,1
Tcpdump is a command line utility shipped with OS X that can perform packet capture. (The tshark utility bundled with Wireshark is very similar.) To perform a wireless packet capture using tcpdump:
Example:
bash-3.2# tcpdump -I -P -i en1 -w /tmp/channel-11.pcap
tcpdump: WARNING: en1: no IPv4 address assigned
tcpdump: listening on en1, link-type IEEE802_11_RADIO (802.11 plus radiotap header), capture size 65535 bytes
^C
897 packets captured
968 packets received by filter
0 packets dropped by kernel
bash-3.2#
If you are running MAC OsX 10.7 (Lion), you can use the graphical program called Wi-Fi Diagnostics. It’s located in the following folder:
/System/Library/CoreServices
Normally this folder is not easily accessible so a quick trick is to open the “Finder” and use the "Go to folder" (“Shift-Command-G”) option; this will open up a dialog box in which you can enter “/System/Library/CoreServices” and press return. There you will find the Wi-Fi Diagnostics program.
Here is a example of using the tool to monitor Wi-Fi Performance:
Here is any example of using the tool to record Wi-Fi Events:
Here is any example of how to enable the Debug logs to be taken, this will allow you to see all messages that occur at the driver and supplicant level on the MAC
Here is an example of using the tool to capture raw Wireless frames that can be heard by the MAC.
In order to capture a complete wireless trace, select “Capture Raw Frames”.
Check the box to disconnect from the network and select the channel that is being used by the client that are you sniffing. as you want to capture all data send and received on the network since we are using the sniffer to capture another wireless client’s frames
The trace will start after pushing the “Start Capturing” Button. Once you have finished the trace, push the “Stop Capturing” button and click on “Continue”, a dialog will ask to either save the report to the Finder desktop or send it via an email.
Another option on the MAC to capture a wireless trace is to use Wireshark. This is a free program that can be downloaded from http://wireshark.org. (Note: this requires that X11 be installed - for OS X 10.8, this means downloading and installing Xquartz.)
Once installed and started, select the capture option and fill out the dialog as follows:
W
I would love to know what all the columns returned by airport -s stand for.
I note that my devices (iphone etc) do not seemless roam between my apple airport and cisco 877w. Both devices have identical SSID's but what else needs to be the same to allow roaming?
boothby 00:1f:f3:e2:01:4c -82 9 Y GB WPA2(PSK/AES/AES)
boothby 58:1f:aa:c4:a9:65 -81 1 Y GB WPA2(PSK/AES/AES)
boothby 68:ef:bd:ff:c4:60 -76 7 N -- WPA2(PSK/AES/AES)
channel? ht? cc? security?
SSID - SSID (i.e. ESSID)
BSSID - BSSID (MAC of the AP)
RSSI - Receive signal strength
CHANNEL - channel (a +1 or -1 after the channel is for 11n 40MHz wide, to denote 20 above or 20 below)
HT - High Throughput (i.e. are 11n rates supported)
SECURITY - key management (WPA, WPA2)
Auth - (PSK or 802.1x [i.e. EAP])
Unicast - Unicast key (AES or TKIP)
Group - group key (AES or TKIP)
For more explanation, consult a text on 802.11
As far as seamless roaming between APs ... well it's not guaranteed (unless they're all Cisco , but if you:
you've got the best chance of getting it to work.
Cheers,
Aaron
Tim, Aaron,
You can lock WireShark to a particular channel within OS X. Here's how:
Launch Mountain Lion Wi-FI Diagnostics Utility (as mentioned above)
Go to the Packet Capture Window and select the desired channel, but do not click "Continue"
Launch WireShark and it will only capture on the selected channel - no scanning of channels
You can also display channel/frequency & other RF details by customizing the columns under WireShark preferences
Eric
OS X Wi-Fi utilities is easier to find in Mountain Lion
Press the option key while clicking on the Wi-FI Indicactor on the right side of the top bar.
You wll see extended information of the wireless networks and then a menu selection for Wi-FI diagnostics towards the bottom.
Eric
What is the difference between using the "airport" utility, ie:
"sudo /System/Library/PrivateFrameworks/Apple80211.framework/Versions/Current/Resources/airport --channel=1"
followed by: "tcpdump -I -P -i en1 -w /tmp/channel-1.pcap"
and using airportd: ie
Seems like both of them put the interface into "monitor mode", and both capture 802.11 frames (including management & control) but the latter disconnects you from any connected nets, and the former does not.
Put another way, does using the airport util. actually capture all frames in monitor mode? Seems like it does ( I still see control/mgmnt frames), but I remain 'connected' to network.
Answering my own question here, after discussing this elsewhere:
Kind of obvious now, but point being: If a radio is transmitting, there's no way for it to be receiving at the same time. Hence, even if OSX is just probing to remain associated, the chance is there to miss frames. "airportd" method should be used when absolute accuracy is required.
"airport" method can still be useful for a quick capture, especially if you want to see the frames real-time. Example: wanting to quickly verify data-rates being supported/mandatory, you can see that fly by in the tcpdump stream (just leave off the -w flag).
Can you please tell me how do you sniff in 80 MHz mode?? I use the airport utility to set the channel. the 1,-1 after the channel number tells about the secondary 40MHz channel. However, when I set channel number, I am not able to capture 80MHz data packets. The alternative method is - I associate to an AP which is operating in 80MHz, and then start wireshark. Now it captures all 80MHz packets as well. How do I configure it to sniff 80MHz packets without associating to an AP?
As of today, the only way to sniff 80mhz channels is with an AP in sniffer mode. I have not check to see what the OSX 10.10 release can do, but if I find a way to sniff in 80mhz with OS X 10.10, I'll post an update.
Another tool that can be used is "AirTool": http://www.adriangranados.com/apps/airtool
It's free and the author also makes several other useful Wi-Fi related applications for both OSX and iOS.
Looks like Wi-Fi Diagnostics is deprecated so may want to add info about Wireless Diagnostics.
This is included in Mac OS 10.11.6 (El Capitan), not sure if included in earlier versions.
Launch Wireless Diagnostics (located @ /System/Library/CoreServices/Applications) by using the command + click on the Wi-Fi icon on the title bar, use the Spotlight search option, or simply browse the hard drive.
Then select Window > Sniffer option.
Good tip! Minor correction: it's option + click Wi-Fi icon, not command.
Hello! Thanks for posting this.
I'm trying to capture some packets from a device on my network and I'm having some trouble.
Using a MacBook Pro running MacOS Sierra, and WireShark.
Here's the output from my terminal:
$ sudo /usr/libexec/airportd en0 sniff 11
Capturing 802.11 frames on en0.
^CSession saved to /tmp/airportSniffnktkMH.cap.
I am able to run the capture and perform some actions on the device. The private IP of the device is 192.168.1.9. The actions work correctly, so we know some packets were sent/received.
Then I open that file in WireShark, and I can't seem to find any packets sent/received on that IP.
Filters I have tried:
(ip.src==192.168.1.9)&&(ip.dst==192.168.1.9)
or
(ip.addr==192.168.1.9)
or
or
Unfortunately, using any of the filters above, I'm not getting any packets found.
Can anyone tell me what I'm doing wrong?
Kip C.
Is the Wi-Fi network you are sniffing encrypted? If so, you will not see the ip level details without importing the keys. This is possible in Wireshark, but not with the airportd command
Hello, thanks for your reply!
The WiFi network is encrypted, yes. I have admin access to the router, so can you tell me how I should go about getting the private key?
Sorry for the beginner-level questions...
Kip C.
Edit:
So I have now configured WireShark with my WPA password.
"wpa-pwd" - "MyPassword:MySSID"
When I run a capture with WireShark on my laptop, however, it appears like it's only capturing packets going to/from my laptop, and not capturing packets to/from the device I'm interested in.
My WireShark is already in promiscuous mode, so is there something else I'm missing?
Thanks!
