chanchan1029
See configuration
Problem
WLC-5508 (ACTIVE) <-> WLC-5508 (HA) HA configuration not issues
TEST
C6509 (VSS) in the WLC-5508 (HA) management ICMP test not communicate
KrSeHoF42_Ci6509Sw1#ping 10.192.129.101
Sending 5, 100-byte ICMP Echos to 10.192.129.101, timeout is 2 seconds:
Success rate is 0 percent (0/5)
WLC-5508 (HA) in the C6509 (VSS)G/W IP ICMP test communication is normal
(Cisco Controller) >ping 10.192.129.254
Send count=3, Receive count=3 from 10.192.129.254
This is not even basic communication.
Please make sure that os bug.?
Version 7.3.101.0
Boot Capture screen is a log
Starting Redundancy: Starting Peer Search Timer of 120 seconds
Cannot open the file /mnt/application/ha/InheritedApCount.txt
Redundancy Link is down. Entering maintenance mode to avoid network conflict.
Entering maintenance mode...
ok
WLC-5508 INTERFACE INFO
WLC-5508 (ACTIVE) INTERFACE INFO
Interface Name                 Port Vlan Id  IP Address      Type    Ap Mgr Guest
ext_ap                             3    untagged 192.168.1.245   Dynamic No     No
management                     1    untagged 10.192.129.100  Static  Yes    No
redundancy-management     1    untagged 10.192.129.99   Static  No     No
redundancy-port                -    untagged 169.254.129.99  Static  No     No
service-port                     N/A  N/A      10.10.10.10     Static  No     No
virtual                            N/A  N/A      1.1.1.1         Static  No     No
WLC-5508 (HA) INTERFACE INFO
management                       1    untagged 10.192.129.101  Static  Yes    No
redundancy-management      1    untagged 10.192.129.102  Static  No     No
redundancy-port                  -    untagged 169.254.129.102 Static  No     No
service-port                       N/A       N/A      0.0.0.0         DHCP    No     No
2.Service-port ip input PC ICMP normal controller can not access HTTPS
Thank you
yyoon
Version 7.3.101.0 bug
7.4.110.0 upgrade progress
AP SSO normal sink
Pedro Ivo Silva
I have exactly same error with version 7.4.110.0.
I'll try to upgrade to another version... Maybe some memory rebuild process when we try to upgrade have fixed "yyoon" issue...
Error during boot process:
(Cisco Controller) >show redundancy summary
 Redundancy Mode = SSO ENABLED
     Local State = MAINTENANCE
      Peer State = UNKNOWN - Communication Down
            Unit = Secondary - HA SKU
         Unit ID = E4:C7:22:AA:FE:40
Redundancy State = Non Redundant
    Mobility MAC = E4:C7:22:AA:FE:40
Maintenance Mode = Enabled
Maintenance cause= Negotiation Timeout
Redundancy Management IP Address................. 172.30.100.252
Peer Redundancy Management IP Address............ 172.30.100.251
Redundancy Port IP Address....................... 169.254.100.252
Peer Redundancy Port IP Address.................. 169.254.100.251
