Jeffrey Keown
Cisco controllers that support channeling actually use a simplified version of channeling referred to as "LAG", Link Aggregation.
LAG on the following WLC platforms requires that the switch connected to the other end of the channel be configured for source/destination ip (src-dst-ip) etherchannel load balancing:
4400 Series
WiSM1
3750G
WiSM2
http://www.cisco.com/en/US/docs/wireless/controller/7.0/configuration/guide/c70mint.html
"The recommended load-balancing method for Catalyst switches is src-dest-ip (CLI command: port-channel load-balance src_dest_ip)."
LAG on 5508 and 2504 (2504 LAG Support introduced in 7.4 code) WLC's does not require src-dst-ip. Any load balacing method will work.
With 6500's running in pfc3 mode, the channel load balance method is 'src-dst-ip enhanced' or 'src-dst-ip vlan included' by default, which will often cause packet forwarding problems with WiSM controllers (referenced in the link above).
6500's pfc mode can be verified with this command:
6500#show platform hardware pfc mode
PFC operating mode : PFC3A
The ability to revert to 'src-dst-ip' only was not originally in 6500 code.
This was added as an enhancement in 12.2(33)SXH6 and 12.2(33)SXI3 as documented in the following enhancement bug:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCso79925
Once running this code, the correct port channel load balancing can be enabled with the following configuration:
Config t
port-channel load-balance src-dst-ip exclude vlan
6500 VSS pairs will most likely be operating in pfc3 mode, as pfc3's are required for VSS support.
Assuming that the channel load balancing algorithm is correct, WLC's should be able to form Lag etherchannels with ports connected to both VSS physical switches, as the VSS is one 'logical' switch.
pilcher
I am having problems configuring this with our newly-acquired WLC which we have connected to
our 6500 VSS running 12.2(33)SXI9.
When I try to configure the port-channel load-balance on the running system as described I am not
able to use the exclude vlan option. Have I missed something?
Jeffrey Keown
Hi John,
I just loaded this code on a 6500 and it works as expected.  Can you provide some outputs?
Here are outputs from my lab verification:
VSS#sho ver
Cisco IOS Software, s72033_rp Software (s72033_rp-ADVENTERPRISE_WAN-M), Version 12.2(33)SXI9, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Fri 24-Feb-12 21:38 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
VSS uptime is 5 minutes
Uptime for this control processor is 8 minutes
Time since VSS switched to active is 4 minutes
System returned to ROM by reload at 13:04:57 UTC Fri Aug 31 2012 (SP by reload)
System image file is "sup-bootdisk:s72033-adventerprise_wan-mz.122-33.SXI9.bin"
Last reload reason: Unknown reason
cisco WS-C6509 (R7000) processor (revision 3.0) with 983008K/65536K bytes of memory.
Processor board ID TSC0716009Y
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
3 Virtual Ethernet interfaces
102 Gigabit Ethernet interfaces
VSS#show platform hardware pfc mode
PFC operating mode : PFC3C
Configured PFC operating mode : None
VSS#show mod
Mod Ports Card Type                              Model              Serial No.
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1207G25F
Mod MAC addresses                       Hw    Fw           Sw           Status
  5  0019.e8bb.0874 to 0019.e8bb.087b   2.0   8.5(2)       12.2(33)SXI9 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL1205ER2Y  1.0    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL1205F0CM  1.0    Ok
Mod  Online Diag Status
  5  Pass
VSS#sho etherc load
EtherChannel Load-Balancing Configuration:
        mpls label-ip
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
  IPv4: Source XOR Destination IP address
  IPv6: Source XOR Destination IP address
  MPLS: Label or IP
VSS#conf
Configuring from terminal, memory, or network [terminal]?
Enter configuration commands, one per line.  End with CNTL/Z.
VSS(config)#port-channel load-balance ?
  dst-ip                 Dst IP Addr
  dst-mac                Dst Mac Addr
  dst-mixed-ip-port      Dst IP Addr and TCP/UDP Port
  dst-port               Dst TCP/UDP Port
  mpls                   Load Balancing for MPLS packets
  src-dst-ip             Src XOR Dst IP Addr
  src-dst-mac            Src XOR Dst Mac Addr
  src-dst-mixed-ip-port  Src XOR Dst IP Addr and TCP/UDP Port
  src-dst-port           Src XOR Dst TCP/UDP Port
  src-ip                 Src IP Addr
  src-mac                Src Mac Addr
  src-mixed-ip-port      Src IP Addr and TCP/UDP Port
  src-port               Src TCP/UDP Port
VSS(config)#port-channel load-balance src-dst-ip ?
  exclude  Exclusion parameters
  <cr>
VSS(config)#port-channel load-balance src-dst-ip exclude ?
  vlan  Exclude vlan
VSS(config)#port-channel load-balance src-dst-ip exclude vlan
VSS(config)#end
VSS#show etherchannel load-balance
        src-dst-ip
        mpls label-ip
  MPLS: Label or IP
VSS#
pilcher
Hello Jeffrey Many thanks for the response. Here is the similar output in my case. Any idea what I am missing? Regards, John. TLABSFVSSA#show ver Cisco IOS Software, s72033_rp Software (s72033_rp-IPSERVICESK9_WAN-M), Version 12.2(33)SXI9, RELEASE SOFTWARE (fc2) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2012 by Cisco Systems, Inc. Compiled Fri 24-Feb-12 21:38 by prod_rel_team ROM: System Bootstrap, Version 12.2(17r)SX6, RELEASE SOFTWARE (fc1) TLABSFVSSA uptime is 40 weeks, 2 days, 4 hours, 47 minutes Uptime for this control processor is 4 weeks, 1 day, 23 hours, 30 minutes Time since TLABSFVSSA switched to active is 4 weeks, 1 day, 23 hours, 18 minutes System returned to ROM by Stateful Switchover at 17:08:47 SAST Wed Aug 1 2012 (SP by Admin requested switchover during ISSU) System restarted at 17:12:19 SAST Wed Aug 1 2012 System image file is "sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXI9.bin" Last reload reason: Reason unspecified cisco WS-C6506-E (R7000) processor (revision 1.2) with 983008K/65536K bytes of memory. Processor board ID SAL1412DQ3E SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache Last reset from s/w reset 8 Virtual Ethernet interfaces 150 Gigabit Ethernet interfaces 36 Ten Gigabit Ethernet interfaces 1917K bytes of non-volatile configuration memory. 8192K bytes of packet buffer memory. 65536K bytes of Flash internal SIMM (Sector size 512K). Configuration register is 0x2102 TLABSFVSSA#show platform hard pfc mode PFC operating mode : PFC3C Configured PFC operating mode : None TLABSFVSSA#show mod Mod Ports Card Type                              Model              Serial No. --- ----- -------------------------------------- ------------------ -----------   1  24  CEF720 24 port 1000mb SFP              WS-X6724-SFP      SAL1412DAF5   2  48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX    SAL1411D40P   3    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1201BTPV   4    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1152BFUG   5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL1412DDY3 Mod MAC addresses                      Hw    Fw          Sw          Status --- ---------------------------------- ------ ------------ ------------ -------   1  68ef.bd7e.9268 to 68ef.bd7e.927f  4.3  12.2(18r)S1  12.2(33)SXI9 Ok   2  68ef.bd34.48d0 to 68ef.bd34.48ff  3.4  12.2(18r)S1  12.2(33)SXI9 Ok   3  001a.6c9f.0420 to 001a.6c9f.0427  1.3  12.2(18r)S1  12.2(33)SXI9 Ok   4  001a.6c9e.fc88 to 001a.6c9e.fc8f  1.3  12.2(18r)S1  12.2(33)SXI9 Ok   5  0025.84bf.9150 to 0025.84bf.9157  3.2  8.5(3)      12.2(33)SXI9 Ok Mod  Sub-Module                  Model              Serial      Hw    Status ---- --------------------------- ------------------ ----------- ------- -------   1  Centralized Forwarding Card WS-F6700-CFC      SAL1410CKEL  4.1    Ok   2  Centralized Forwarding Card WS-F6700-CFC      SAL1411D79T  4.1    Ok   3  Distributed Forwarding Card WS-F6700-DFC3CXL  SAL1202CK17  1.0    Ok   4  Distributed Forwarding Card WS-F6700-DFC3CXL  SAL1202CK0U  1.0    Ok   5  Policy Feature Card 3      VS-F6K-PFC3C      SAL1412DGP2  1.1    Ok   5  MSFC3 Daughterboard        VS-F6K-MSFC3      SAL1412DDM3  2.1    Ok Mod  Online Diag Status ---- -------------------   1  Pass   2  Pass   3  Pass   4  Pass   5  Pass TLABSFVSSA#show etherchan load EtherChannel Load-Balancing Configuration:         src-dst-ip vlan included         mpls label-ip EtherChannel Load-Balancing Addresses Used Per-Protocol: Non-IP: Source XOR Destination MAC address   IPv4: Source XOR Destination IP address   IPv6: Source XOR Destination IP address   MPLS: Label or IP TLABSFVSSA#config t Enter configuration commands, one per line.  End with CNTL/Z. TLABSFVSSA(config)#port-channel load-balance ?   dst-ip                Dst IP Addr   dst-mac                Dst Mac Addr   dst-mixed-ip-port      Dst IP Addr and TCP/UDP Port   dst-port              Dst TCP/UDP Port   mpls                  Load Balancing for MPLS packets   src-dst-ip            Src XOR Dst IP Addr   src-dst-mac            Src XOR Dst Mac Addr   src-dst-mixed-ip-port  Src XOR Dst IP Addr and TCP/UDP Port   src-dst-port          Src XOR Dst TCP/UDP Port   src-ip                Src IP Addr   src-mac                Src Mac Addr   src-mixed-ip-port      Src IP Addr and TCP/UDP Port   src-port              Src TCP/UDP Port TLABSFVSSA(config)#port-channel load-balance src-dst-ip ?   switch  Specify switch id   TLABSFVSSA(config)#port-channel load-balance src-dst-ip exclude? % Unrecognized command TLABSFVSSA(config)#end TLABSFVSSA#exit
pilcher
Sorry about the formatting that happened above. It lost all the end-of-line information when I pressed the
Add Comment button. Hope you can decipher it. John.
K D
Hi Jeffrey,
we are running 5508 controller and connecting to a VSS pair.
Cisco document for version 7.3 WLC code recommends
"port-channel load-balance src-dst-ip" on the port channel config. Is this still valid for 5508 WLC connected to a 6500 VSS pair?
Currently there is no load balancing command specified, so I assume src-mac would be the default.
Aaron
The src-dst-ip requirement only applied to the 4400 based platforms (4404, 4402, WiSM-1 and 3750G.)  You don't need to worry about with the newer platforms.
Best,
Aaron
K D
Hi Aaron,
Thanks for your reply. The below link advises that src-dst-ip is recommended?
http://www.cisco.com/en/US/partner/docs/wireless/controller/7.3/configuration/guide/b_wlc-cg_chapter_011.html#d110109e2504a1635
is that only for 4400 based WLC?
r
kingslin
Aaron
Kingslin,
That section of the documentation is obsolete.  I.e. you only need to worry about "src-dst-ip" on the 4400-based WLCs whose final resting branch is 7.0, so that verbiage doesn't belong in our post-7.0 documentation.  I've sent feedback to the doc writers to remove it.
Aaron
Aaron
Following up to myself here .. somehow between April and July, I managed to forget that the src-dst-ip restriction does pertain to the WiSM2 (although not to the 5508.)
I.e. this article is correct - use src-dst-ip for any of: {4400, WiSM1, 3750G or WiSM2}
Aaron
Nate Carlson
Community Member
Aaron,
Could you do me a favor and confirm if the src-dst-ip option applies to the 2504's? It seems like they are a somewhat older platform that has had LAG added.. so just not sure.
I'm currently doing lab testing with them hanging off a 3750 which only supports src-dst-ip on the current software (updating to see if I can get more options), but the 6509 that the 2504s will eventually be on are set to 'src-dst-mixed-ip-port', and we need to keep it that way.
Thanks!
-Nate
Jeffrey Keown
Hi Nate,
good question.  As Lag support is introduced over time, this document needs to evolve
Like the 5508, the 2504 shouldn't require src-dst-ip.  It's 5508 based, and has doesn't have dual data planes like the Wism2 (which does require src-dst-ip).
thanks
Jeff
Nate Carlson
Community Member
Excellent, thanks! That's what I was hoping to hear.
panayiotiscy
Level 4
Level 4
hello all, i am jumping into this thread just to ask a very close question related to the above. in a scenario with 2 x 8500 in HA SSO over a VSS block, when it comes to the etherchannel configuration (LAG), what is the best practice?
-create 1 port-channel and attach the physical ports of the 2x8500 in it or to create 2 separate port-channels, one for each WLC?
Jeffrey Keown
Each controller needs a separate port channel.
If you were to bundle all switch ports for both controllers into one switch side port channel group, you'd experience very bad packet forwarding issues.
With VSS, it doesn't matter if a given controller's connected ports are spanned across both switches, the important thing is that all of the physical channel member links are presented to each controller as a 'single logical port channel'.
let me know if this helps.
thanks
Jeff
panayiotiscy
Level 4
Level 4
Hello Jeff,
Thanks for sorting things out. I had this in my mind but since that is my first deployment i wanted to verify this.
