04-28-2015 03:55 AM - edited 11-18-2020 03:10 AM
Final code 8.0.120.0 now posted in CCO, thanks for your interest.
| 8.0.115.30 | |
| CSCuq90632 | 3702 crashed with a traceback |
| CSCuu81895 | New 1572 out of box AP in local mode not starting CAPWAP process |
| 8.0.115.26 | |
| CSCuu37077 | 3600P limited channels/power similar to CSCus35411 |
| CSCuu20683 | RAP might lose the Native VLAN configuration on downgrade from 8.1 |
| CSCuu20256 | Traffic drop on WLCs with 7.6.130.206 and PMIPv6 |
| CSCut05252 | OEAP: Auth rejected because of challenge failure ReasonCode: 15 |
| CSCut47761 | PMIPv6 Client crash with .1x auth when user name have colon ':' |
| 8.0.115.18 | |
| CSCun56310 | #LWAPP-3-VENDOR_PLD_VALIDATE_ERR: SPAM_VENDOR_SPECIFIC_PAYLOAD(185) |
| CSCus44831 | 1702 AP reports power error with 802.3af power source |
| CSCus25256 | 1130 Flexconnect APs sometimes lose bridge-group configuration |
| CSCuq97914 | PI 1.4 cannot finish auditing WLC |
| CSCus26067 | HA failing after upgrade to 8.0 due to gateway ARP source mac |
| CSCus72994 | WLC Crash on Task Name:DHCP Socket Task |
| CSCus94968 | osapiMalloc accepting negative size buffers |
| CSCut98741 | WLC Monitor page needs to support session timeout |
| CSCut14210 | Flexconnect arp-cache enabled - AP is not responding on behalf of client |
| CSCus30769 | BSSID containing itself and also adding itself to client exclusion list. |
| CSCuq86269 | DFS detection due to broadcom spurious emissions |
| 8.0.115.11 | |
| CSCus48787 | AP:Radio d1 reset: FW: vec=36 pc=10FC4, irq/mac stat=20000/80 |
| CSCur53041 | DTLS connection failure. |
| CSCus39358 | Apple and Android not connecting to WPA2-AES on OEAP600 8.0.110 |
| CSCus44802 | WLAN NAS-id is not applied when AP Group NAS-id is changed |
| CSCus06920 | preauth bit set in RSN IE when wlan is wpa2AES |
| CSCut96026 | SGT remains for client when moving between WLANs with Fast SSID change |
| CSCuq48218 | WLC cannot process multiple sub-attributes in single RADIUS VSA |
| CSCur45862 | AP's cannot discover wlc through option 43 on build 8.0.100 |
| CSCuq09859 | APs sending GARP and ARP requests aprox every 2 seconds. |
| CSCuq48800 | Low throughput due to UAPSD for Intel 7260 WiFi chipset |
| CSCuo09947 | RADIUS AVP #44 (Acct-Session-ID) to be sent in RADIUS authen messages |
| CSCur45453 | web Gui 8500 new mobility support and SPG configuration to be blocked |
| CSCur56576 | WLC doesn't support 802.11a for Qatar |
| CSCur92472 | PMIPv6: Roaming WLC1->WLC2 don't work, wrong handoff indicator |
| CSCus31292 | Oct 2014 OpenSSL Vulnerabilities |
| CSCus85767 | Flex local switch clients, local dhcp are trying to do central dhcp |
| CSCut45950 | MARCH 2015 OpenSSL Vulnerabilitiess |
| 8.0.115.7 | |
| CSCus45806 | Enable CDP Spare pair TLV for 1570 and 1530 series access points |
| CSCur22714 | Ap3602 trying to contain its own RM3000AC module |
| CSCut26137 | 3702 - Voice Queue stuck, with no new clients able to associate. |
| CSCur37475 | wism2 system crash - at client stats AVL corruption |
| CSCus13594 | slow in getting the DHCP address in the AP2700 |
| CSCur78697 | 1st Hop MAP CAPWAP Restart Due to race condition when seeking RAP2 |
| CSCur72287 | EAPOL Security error seen when 1st HOP MAP Roams from RAP1 to RAP2 |
| CSCus48452 | MAPs do not return to configured channel along with RAP 30 after DFS |
| CSCus49126 | AP3702 floods RTS frames @ 8000pps to departed client |
| CSCuq99230 | AP syslog fails due to default setting 'logging server-arp' |
| CSCus85337 | CAPWAP Restart & Gteway not reachable when MAP roams From RAP1 to RAP2 |
| CSCuq48043 | IPv6 forwarding halts; broadcast queue full |
| CSCur52246 | PMIPv6 GRE key databse gets full during scale testing |
| CSCur71427 | Flex: Client roaming fails "not processing DOT1X_4WAY_COMPLETED_AT_AP" |
| CSCur74954 | central auth + local switching : clients are in idle state always |
| CSCus80059 | WLC always send authen packet to aaa server even no any client in WLC |
| CSCut31679 | Kernel panic -Unhandled kernel unaligned access |
| 8.0.115.3 | |
| CSCuq60042 | Memory leak on WLC when using PMIPv6 clients pem_api.c |
| CSCuq63642 | Internal webpage appears after successful redirect to external webauth |
| CSCur00288 | 8.0.100.0 client is shown with "ip address unknown" and "dhcp required" |
| CSCur30298 | 8500 new mobility support for guest anchor and block spg config |
| CSCur50819 | BEAST Vulnerability not properly resolved in Cisco WLCs |
| CSCur67701 | Image download errors for CAPWAP 7500/8500 |
| CSCus39461 | Radius DNS adds both Network and Management Auth + Acct = Enabled |
| CSCus46861 | LIZRD attack : Denial of Service |
| CSCus64073 | 1700/2700 APs native vlan field missing in Flex tab |
| CSCut07617 | Signal 11 crash at PMIPV6_Thread_1 |
| CSCut26403 | AP1242 does not forward SIP INVITE when SIP-CAC is enabled |
| 8.0.115.2 | |
| CSCus87673 | 3700 AP 5ghz Radio Reset |
| CSCur88864 | 3600 APs with AC module shows 100% Rx utilization on slot-2. |
| CSCur23656 | Cisco IOS and IOSd in IOS-XE : evaluation of SSLv3 POODLE vulnerability |
| CSCuq19142 | LAP/WLC MIC lifetime expiration causes DTLS failure |
| CSCuq54548 | Anchor Memory Leak when Sleeping Client Feature is enabled |
| CSCuq74491 | WLC 8.0.100.0 crashes due to Task Name: apfRogueTask_0 |
| CSCur20154 | HA SSO pair memory leak |
| CSCur96221 | Standby WLC crash at haSSOServiceTask6 |
| CSCus21276 | Kernel Panic on wism2 for 8.0MR1 beta |
| CSCus38268 | Memory Leak on WiSM2 due to SNMPTask on 7.4.121.0 |
| CSCus42727 | JANUARY 2015 OpenSSL Vulnerabilities |
| CSCus55004 | WLC2504 8.0MR1: Kernel Panic with pre-auth ACL and external web-redirect |
Is there any intention for this release to have the various bug fixes from the current 8.0.110.11 build integrated into it?
Also are there any plans to implement the fixes for DFS related issues that are fixed in the 7.6.130.20 build into 8.0mr2, specifically:
CSCuq86252 / CSCuq86269
Cheers,
Will
Hi Will
most of the fixes on 8.0.110.11 will be integrated here, this first beta is "half way" on the total bug count planned for the release. Not all is expected to move into MR2
CSCuq86269 in particular, is still under evaluation for 8.0 inclusion (there are some steps needed)
regards
Hello Javier,
If it's a known bug, why wouldn't be integrated into MR2?! It doesn't make sense. All known bugs that have been resolved on the "Escalation" builds should be on MR2. That would avoid more TAC cases to be opened.
hi Gustavo
Things are more complex that just that. Escalation builds allow us quite a large freedom to handle what is included or not on them. CCO builds have a very strict commit procedure, plus a time window for posting, so not all issues may be included until some requirements are met and timelines can be satisfied
Just to add more details: In this particular bug, as it is a DFS radio change, it has to pass compliance certification on each radio firmware version that it is included, so tests done for 7.4 (it is included already in upcoming 7.4.140.0), need to be totally re-done for 8.0, and they take 2 weeks.
I do a continuous evaluation on what goes into MR releases, and we try as much as possible to include fixes to lower any potential TAC cases. if a known issue is evaluated as pervasive and has a viable fix, we try to include it
regards
Hello Javier,
I got your point. I didn't express myself clearly (I think). What I meant was that all known bugs that were fixed on "Escalation" builds for the same trail (read 8.0.110.x) should be commited to be on MR2. I know that the code may vary from trail to trail (read 7.6 to 8.0) and tests should be done.
Anyway, thanks for the information. I didn't know all these steps behind the process.
Best Regards
It appears that most of the fixed bugs here are also fixed in 8.1; are you aware of any critical ones that didn't make it into the release?
Obviously 8.1 carries the risk of exciting new bugs.. but, well, shiny! ;)
Thank you Javier for sharing latest release 8.0.115.x availability - 8.0MR2 Beta with community user, appreciated +5 :-)
hi Nate
All of the critical needed fixes in 8.0 were carried over to 8.1 release
regards
Great, thanks!
I'll let 8.0.115.11 bake for a week or so probably, and if all is well, start the rollout process for 8.1. :)
Thanks for sharing the information and new releases!
Question about which release is recommended:
Is 8.0.115.18 advisable over 8.0.110.13?
For example I can't find
CSCus87673 - 3700 AP 5ghz Radio Reset
in the release notes for 8.0.110.13, while it is already in 8.0.115.2.
Thanks in advance!
Hi Bart
8.0.110.x is 8.0MR1 Escalation branch, and as such, it follows a more aggressive bug commit process
Customers are advised to move to 8.0MR2 official release (8.0.120.0) when it is available in CCO, unless they are explicitly affected by a bug fixed in escalation code
Until 8.0MR2 is in CCO, the recommendation would be to use either 8.0.110.x or 8.0.115.x (this beta), as both branches have the same 8.0 critical bugs fixed
For customers with special needs/bugs reported, we will continue to support 110.x esc then, 120.x esc for additional bug fixes, until 8.0MR3 (8.0.130.0) future release is preparared
regards
Hi Javier,
Can you confirm for me whether the 3602i (-E reg domain) received any DFS changes in 8.0.115.18 - it seems we are still getting stung with a large volume of DFS hits in a large public venue when there are lots of devices on the network.
Will
hi Will
we included fix for 2600/3600 families on 8.0MR2, that should improve around 10-30% on the sites that due to RF conditions may generate DFS hits
There is a second fix we are working in, that should improve a lot the rate, please send me private message and I can work with you on details about it
regards
Any dates for when MR2 will post? The last I heard was by the end of June.
I have tried to escalation but didn't work so I though I post in this..
Controller: 5508
AP: 1142 and 2702i
Software: 8.0.100.0
Regularity Domain: NZ
I have received couple of universal domain access points and to support this in current environment I have to upgrade current Airos to 8.0.110.x or 8.0.115.x or 8.1.102.0
Almost all AirOS has the critical bug with the DDos attack.
I have following questions,
any suggestion which one is the best AirOs to upgrade will be appreciated.
Nilay.
