Saravanan Lakshmanan
    Introduction
    central dhcp Processing - Locally switched remote wireless client getting ip from WLC or via WLC.
    When using Flexconnect local switching, Dhcp request is sent/bridged to the flexconnect AP connected local switch. On Enabling central dhcp option from flexconnect group, dhcp request can be forwarded to WLC for DHCP ip assignment to the locally switched wlan.
    How to Configure
    Create Flexconnect group.
    On central dhcp tab, configure the wlan id and check central dhcp and click add. Repeat the step if multiple WLANs are used.
    Add intended APs to that group.
    How it works
    Using the flexconnect group feature -> 'central dhcp' the remote wireless client that is locally switched will get an ip from WLC's interface that is mapped to that locally switched wlan. Can use WLC's internal or external dhcp server.
    WLAN - Locally switched
    From WLAN tab -> Interface mapping for wlan id 5 is vlan120 = 120
    From AP's Flexconnect tab -> AP's WLAN to vlan mapping -> wlan id 5, vlan id - 120. Without AP group configured, still client will get an ip from vlan 120.
    Scalability is achieved using AP group
    Use AP Group to override vlan for specific wlan and add the flexconnect ap to that AP group.
    From WLC's interface tab - Create vlan2000 interface with interface ip, gateway, mask and dhcp server(internal/external). vlan id 2000 is similar local vlan at the site.
    From WLAN tab -> Interface mapping for wlan id 5 is vlan120 = 120. It doesn't matter what is configured here, ap group will override the vlan interface.
    From AP group map the ssid with interface vlan 2000.
    From AP's Flexconnect tab -> AP's WLAN to vlan mapping -> wlan id 5 to vlan id - 2000.
    Troubleshooting
    'Client debug' on WLC will show the debug transaction until 'RUN' state for central dhcp feature.
    Example
    Let say there are 3 sites, each using different vlan ie., 100, 200, 300 and using same ssid ie., ssid-remote.
    1. create three different interface on WLC i.e, vlan - 100, 200, 300 based on the remote location.
    2. configure internal/external dhcp scope for these vlan - 100, 200 & 300.
    3. On WLC it doesn't matter what interface configured for ssid-remote ie., management.
    4. configure 3 AP groups. AP group 1 with ssid-remote mapped to 100, AP group 2 with 200 and 3 with 300 for same ssid.
    5. Add the respective APs to those AP group
    6. On individual AP map the ssid-remote with respective vlan ie., ssid-remote with 100,...
    pchinchk
    So Vlan 100, 200 and 300 (which are on remote site) should be defined on the central switched network?
    i got a setup in which the remote and central locations are connected through L3 link and the VLANs at the locations do not talk with each other. Hence the vlans are remote are not defined on the central location's core switch.
    thank you in advance.
    ajc
    Level 7
    Level 7
    Hi Saravanan,
    If you are routing the WLC interface subnets locally in the central location and also advertising the same subnet from the remote site, how do you handle this situation?. Maybe I am misunderstanding something, please clarify.
