Rajan Parmar
    Introduction
    How to Configuring an Access-Point as a Repeater
    Commands on Repeater
    We used the following commands on the Repeater
    First of all there should be a root device, to which the clients are already able to connect fine.
    We should know the name of the SSID that is being used on the Root Device
    On the repeater also, we should set the same authentication and encryption parameters that we have on the Root device.
    In addition to the above, we set the following commands on the root and the Root Device
    Topology
    Configuration
    AP# configure terminal
    AP(config)# interface dot11radio 0
    AP(config-if)# ssid ####
    AP(config-ssid)# infrastructure-ssid
    AP(config-ssid)# exit
    AP(config-if)# station-role repeater
    AP(config-if)# dot11 extensions aironet
    AP(config-if)# parent 1 ####.####.####.####(mac address of the root)
    AP(config-if)# end
    Commands on Root
    used the following commands on the Root
    AP(config-if)# station-role root
    AP(config-if)# end
    You can setup repeater via GUI also.
    Reference
    Configuring Repeater and Standby Access Points
