TCC_2
Level 10
Level 10
Resolution
A Service Set Identifier (SSID) is a unique identifier that wireless networking devices use to establish and maintain wireless connectivity. Multiple Cisco Access Points (APs) on a network or sub-network can use the same SSIDs. SSIDs are case sensitive and can contain up to 32 alphanumeric characters. Spaces cannot be included in SSIDs.
Up to 16 SSIDs can be configured on the Cisco 1200 series AP, and different configuration settings can be assigned to each SSID. All of the SSIDs are active at the same time; that is, client devices can associate to the AP through any of the SSIDs. These are the settings that can be assigned to each SSID:
  • VLAN
  • Client Authentication Method
For detailed information on the client authentication types, refer to Configuring Authentication Types.
For more information on multiple SSIDs, refer to Configuring Multiple SSIDs.
Note: To use more than one SSID, VLAN must be configured.
Problem Type
Configure / Configuration issues
Products
Access point
Ovidiu Serbu
Community Member
Links expired.
Forbidden File or Application
The file or application you are trying to access may require additional entitlement or you are trying to access a file with an invalid name. Additional entitlement levels are granted based on a users relationship with Cisco on a per-application basis.
If you feel you have reached this page in error, please try one of the following methods to locate your document:
  1. If you are manually entering the URL into your browser location bar, be sure to include the file name of the page you are trying to access (file names typically end in .htm, .html or .shtml).
  2. Use the Search feature located in the upper right section of this page.
  3. Return to the Cisco.com Home or select a primary site area from the top navigation bar.
  4. Consult with your Cisco Account Manager to confirm you have the appropriate entitlement to access this page.
If you would like to contact someone about this problem, please click on the Contacts & Feedback link below.
