Resolution
RTOS is a kernal file. It is mandatory to run the same version of the Real-Time Operating System (RTOS) on all controllers in the same mobility group.
For Airespace products, *.aes file contains the recovery image which has three files in a compresses format. RTOS is one of those files , other 2 being the actual IOS and Bootloader file. RTOS is usaully installed with other 2 files when you download the *.aes file.
Refer the following URLs for downloading softwares
- for downloading latest .aes file of 4400 series controller.
Problem Type
Technical product specification / features
Software issues
Products
Wireless LAN Controllers
