stefanorm
Community Member
Hi Nicolas
previosly i had solved the "web-auth certificate warning issue"
input on CLI the command
*config network web-auth secureweb disable
recently i have update my WLC on  version 7.0.240.0
the warning come back out again , and the  * command is not more present!!!
please any suggestion?
shihab2007pk
hi daviwatk,
we have WLC 2504 conroller and 7 APs configured and its working fine. if you an guide me to do the below things:
1. the guest SSID configured web authentication- passthrogh option with entering email address. how to retreive all the email address list which guest users entered on web authentication portal.
2. how to make band width limitation for guest SSID (we have 100mbps connection we need to limit for guest SSID to 30mbps).
if you can help me to sort out this would be great!.
thanks,
shihab
