9800-CL AWS Configuration Issue
ritchie65
I have a 9800-CL in AWS which is reachable via GUI and CLI.
When I try to add a WLAN, it wil not accept any WLAN number and the security tab is completely blank with no options at all.
I don't believe this to be a licensing issue as the licennses are per AP, as I understand it.
Could there be some missing/required config to be completed bbefore a WLAN can be added?
Ritchie
Mark Elsen
       >...Could there be some missing/required config to be completed bbefore a WLAN can be added?
 - Review the current configuration which you have already with the CLI command : show tech wireless , have the output reviewed by :   https://cway.cisco.com/wireless-config-analyzer/
                               Checkout all advisories (for starters!)
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks for the info.
The software version we have to use with this AWS implementation is 17.3.4c as that is the only one available that will support the existing 3700 series APs we have to migrate over (pending these APs being replaced with 9000 series)
Is external communication with Cisco (For the CSLU) mandatory to enable the WLC to be configured correctly?   I ask because we currently cannot ping/trace to external addresses (8.8.8.8, cisco.com, google.com)
Thannks again
Ritchie
                    >... is the only one available that will support the existing 3700 series APs
  Not exactly in  17.9.3 that support was introduced again  because of many customers still having these access points : https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/17-9/release-notes/rn-17-9-9800.html#whats-new-1793   , it's probably advisable to for that version.
           >... Is external communication with Cisco (For the CSLU) mandatory to enable the WLC to be configured correctly?
  - I don't think so , did you already try the WirelessAnalyzer procedure on on your configuration attempts , as mentioned in my initial reply ?
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Scott Fella
I have not tried the 9800-CL in AWS, but in Azure, if you don't use the correct server type, you run into issue like what you have seen.  Since this is a new setup, you might as well delete that instance and create a new instance following the guide and recommendations.  Even though you might of followed it in the first place, doesn't mean something happened.  It doesn't take long to spin up a new one and test again.  You don't need any license to use the 9800 and that will not affect what you see in the GUI/CLI.
-Scott
