cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
access point-air-ap1852i-a-k9c factory reset
josevilches
Dear Community,
I turn to you, since I have the following case... it turns out that some time ago I configured some aps of the ap1852i-a-k9c model to switch them to CAPWAP mode, the issue is that they went with a password that I forgot, I have the I doubt how to reset it to the factory, since when I press the reset button it asks me for a password, so I would like to know some correct way to do it, so that it is completely factory set.
Beforehand thank you very much,
3 RESPUESTAS 3
balaji.bandi
that is correct - for reference follow below guide :
https://www.cisco.com/c/en/us/td/docs/wireless/access_point/1850/hardware/guide/ap1850hwguide.html
BB
perform this action and I still can't factory reset =(
Using the Mode button (see Figure 2) you can:
  • Reset the AP to it’s default factory-shipped configuration
  • Clear the AP’s internal storage including all configuration files
To use the mode button, press, and keep pressed, the mode button on the access point during the AP's boot cycle. Wait until the AP's status LED changes to Amber. During this, the AP console shows a seconds counter, counting the number of seconds the mode button is pressed. Then:
  • To reset the AP to it’s default factory-shipped configuration, keep the mode button pressed for less than 20 seconds. The AP's configuration files are cleared.
This resets all configuration settings to factory defaults, including passwords, WEP keys, the IP address, and the SSID. However, the regulatory domain provisioning is not reset.
  • To clear the AP’s internal storage, including all configuration files, keep the mode button pressed for more than 20 seconds, but less than 60 seconds.
The AP's status LED changes from Amber to Red, and all the files in the AP's storage directory are cleared. This also removes any regulatory domain provisioning made previously.
If you keep the mode button pressed for more than 60 seconds, the mode button is assumed faulty and no changes are made.
bizzard...!
connect console post complete logs ?
BB
