cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
6
Respuestas
Issues enabling 5GHz signal in Access Point AIR-AP1852I-B-K9
ROZAMX
Dear all,
Hopefully you are doing great. This time I'm contacting you since I have an issue with three AP cisco model AIR-AP1852I-B-K9 due that recently were installed and joined to the WLC (Cisco Catalyst 9800-L Wireless Controller 17.3.3) and everything seems to be normal, but those three cannot be enabled for 5GHz:
In the controller:
is there a way to enable the GHz signal or I'm missing somethig?
ROZA.
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
Hi @ROZAMX
Please check the country code that you configured it looks like a compatibility issue.
Please check this out: https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
Ver la solución en mensaje original publicado
6 RESPUESTAS 6
balaji.bandi
Try enabling 5GH from command level :
# show wireless country supported
#no ap dot11 5ghz shutdown
https://www.cisco.com/c/en/us/td/docs/wireless/controller/9800/config-guide/b_wl_16_10_cg/country-codes.html
Make
e sure the NTP and  AP region correct.
BB
Thanks Bajali for reply.
Question: these commands must be typed in the AP CLI or in WLC CLI?
Since I tried in AP CLI and were not recognized.
Thanks!
if the AP device is managed by WLC, then you need to use on the controller.
also check compatible matrix :
BB
Hi @ROZAMX
Dear Daniel
You were right. The issue was about compatibility since the model that we got should be added as US country and also in the advanced options for every ap added in the controller. After done that steps the signal 5Ghz was up.
Thanks!
Looks like you missed my comment before post
Makee sure the NTP and  AP region correct.
glad all good now
BB
