Aironet 1100 authentication open mac-address problems
admin_2
Level 3
Level 3
I have a new C1100 series that is running 12.2(4). I am trying to get mac-address authentication to use my RADIUS Server (Funk SBR). I think I am close, but I have been close for about 12 hours now.
I am using an ssid for the dot11Radio 0 inetface...
interface Dot11Radio0
no ip address
no ip route-cache
ssid INTECUSA
authentication open mac-address sbr
ssid tsunami
authentication open
guest-mode
...and I THINK I have the sbr list correctly defined.
aaa group server radius default
server 158.155.25.201 auth-port 1812 acct-port 1813
aaa authorization network sbr group radius
radius-server host 158.155.25.201 auth-port 1812 acct-port 1813
...The RADIUS server is up and responding client requests.
...and it looks as though the 1100 is trying to do the right thing, but I don't think I have the sbr method list correctly defined. I don't see any traffic actually go out over the network. Here are the debug messages...
CiscoCS1100#show debug
General OS:
AAA Authorization debugging is on
AAA Accounting debugging is on
dot11 aaa:
Mac Authentication debugging is on
(now I plug a card into a laptop.
06:51:07: AAA/ACCT/EVENT/(0000013D): CALL START
06:51:07: AAA/ACCT/NET(0000013D): Rec init, Session Id=126
06:51:07: dot11_aaa_mac_auth: method_list: sbr
06:51:07: dot11_aaa_mac_auth: method_index: 0xFFFFFFFF, req: 0x64EA28
06:51:07: dot11_aaa_mac_auth: client->unique_id: 0x13D
06:51:07: dot11_mac_process_reply: AAA reply for 000c.3002.1f57 FAILED
06:51:07: dot11_aaa_upd_accounting: Updating attributes for user: 000c.3002.1f57
Bryan
derwin
Level 5
Level 5
Bryan,
The problem is on your AAA server
You need to look on it to find out while it is failing this client
David
Not applicable
Thanks for the reply David, but there are no packets going out on the network to the AAA server. Also I think the debug messages I included were incomplete. I just tried to access the network (no setting were changed). here is the debug output. The message...
*21:01:28: AAA/ACCT/NET(00000155): Method list not foundfailed; Cleaning the record up*
Is why I think I am messing up. Again no traffic on the Ethernet side of the 1100 going to the RADIUS server.
21:01:28: AAA/ACCT/EVENT/(00000155): CALL START
21:01:28: AAA/ACCT/NET(00000155): Rec init, Session Id=150
21:01:28: dot11_aaa_mac_auth: method_list: sbr
21:01:28: dot11_aaa_mac_auth: method_index: 0xFFFFFFFF, req: 0x7AB8DC
21:01:28: dot11_aaa_mac_auth: client->unique_id: 0x155
21:01:28: dot11_mac_process_reply: AAA reply for 000c.3002.1f57 FAILED
21:01:28: dot11_aaa_upd_accounting: Updating attributes for user: 000c.3002.1f57
21:01:28: AAA/ACCT/EVENT/(00000155): CALL STOP
21:01:28: AAA/ACCT/CALL STOP(00000155): Sending stop requests
21:01:28: AAA/ACCT(00000155): Sending stop record for NET
21:01:28: AAA/ACCT(00000155):acctdb->rec_count = 0..sending signal
21:01:28: AAA/ACCT(00000155): Interface DB not enqueuedsuccess
21:01:29: dot11_mac_auth_process: remove 000c.3002.1f57 from mac hold list
Thanks again,
Bryan
Hi Bryan
This message is a reply from a AAA server if the AP didnt get a reply from a AAA server then it would show a timeout after it retried a few times
Try a sniffer on the switch port to the AAA server i am sure you will see that the radius server is infact getting the AAA packets
A lot of radius servers will not show failed radius attemps as received requests unles you enable debugging on the AAA server
Not applicable
Figured it out. I was lacking a few things...
The primary reason why traffic wasn't going to the radius server was because I left out this line...
aaa authentication login default group radius local
...I thought that this only applied to logging in for the CLI, but it doesn't. You need it go go to the radius (default server list?) or the auth will stay local to the access point.
Thanks for the help,
Bryan
