cancelar
Mostrar resultados para
Pesquisar em vez de
Queria dizer:
Apresentações
Útil
22
Respostas
AP not join controller
athan1234
Level 8
Level 8
Hello
This AP was working fine a week ago. For some reason, the Ap is not JOIN to the controller.
Do you have any ideas?
(Cisco Controller) show> sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 8.0.133.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.95.16
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
Build Type....................................... DATA + WPS
22 RESPOSTAS 22
Is it usual that the mac address is different?
AP has more than one mac address. It have the ethernet mac address and the radio mac address.
HI @Flavio Miranda  Ok i am going to erase but not erase
capwap ap ?
controller lwapp primary controller
daisy-chaining daisy-chaining enable/disable
dot1x Configure the dot1x username and password
ethernet Configure ethernet parameters like vlan tag id
hostname Configure ap hostname
ip lwapp ap ip command
log-server Configure the syslog server where all LWAPP errors will be logged
mode Configure an AP mode
preferred-mode capwap mode of operation ipv4 or ipv6
primary-base Primary Controller
primed-timer primed-timer enable/disable
secondary-base Secondary Controller
tertiary-base Tertiary Controller
You can do it from the WLC with the command
clear ap config <ap-name> keep-ip-config
I cant see the ap on the controller 🙂
Oh my bad!  Do you speak Portuguese ?
Hello @athan1234
you can try with "capwap ap mode local" from the AP
Espero que la información haya sido útil y si no tienes más preguntas recuerda cerrar el topic, seleccionando la respuesta como "Respuesta correcta"
**Please rate the answer if this information was useful***
**Por favor si la información fue util marca esta respuesta como correcta**
athan1234
Level 8
Level 8
