AP not joining WLC - Regulatory Domain Problems
rponte
Hi Folks,
I have a problem with an AP that is not joining to the WLC. It said problems with the country code but the ap is UX mode.
AP Model: AIR-AP3702I-UXK9
WLC Configured country Codes: VE (Where i am now)
Attached:
AP:
Boot ap process.
Sh version
WLC:
debug capwap events enable
sh ap join stats
sh sysinfo
sh time:
Time............................................. Wed Nov 15 21:19:05 2017
Timezone delta................................... 0:0
Timezone location................................
NTP Servers
NTP Polling Interval......................... 604800
Index NTP Key Index NTP Server Status NTP Msg Auth Status
1 0 10.243.80.1 In Sync AUTH DISABLED
I really appreciate any help please.
Thanks.
2 Accepted Solutions
do :
clear capwap private-config
and reload AP. Once it join then foloow the above doc,
Dont forget to rate helpful posts
5 Replies 5
Sandeep Choudhary
Please check whether this doc helps
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/ux-ap/guide/uxap-mobapp-g.html#pgfId-71697
Hello, i know it but the AP is not joining to the WLC. To do it the AP must be on the WLC already.
do :
it worked for me ... thanks man !!
any idea, why the access point is still not provisioned after reboot? After that the ap cannot join to the wlc anymore and I have to clear the capwap private-config again. After that it joined as unprimed again. All attempts to manually provison it fails after reboot again. The join logs for ap on the wlc say:
*spamApTask3: Oct 08 17:33:54.962: %CAPWAP-3-POST_DECODE_ERR: capwap_ac_sm.c:6494 Post decode processing failed for Config status from AP cc:16:7e:a2:03:80
*spamApTask3: Oct 08 17:33:54.961: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7076 cc:16:7e:a2:03:80: DTLS connection closed forAP 192:168:99:205 (54728), Controller: 192:168:99:11 (5246) Regulatory Domain Mismatch
*spamApTask3: Oct 08 17:33:54.961: %LWAPP-3-RD_ERR4: capwap_ac_sm.c:3435 The system detects an invalid regulatory domain 802.11bg:-E 802.11a:-E for AP cc:16:7e:a2:03:80
*spamApTask3: Oct 08 17:33:54.961: %LOG-3-Q_IND: spam_lrad.c:13368 Universal AP cc:16:7e:a2:03:80 is disabled - Country UX for this APis not configured
*spamApTask3: Oct 08 17:33:54.961: %LWAPP-3-RD_ERR11: spam_lrad.c:13368 Universal AP cc:16:7e:a2:03:80 is disabled - Country UX for this APis not configured
*spamApTask3: Oct 08 17:33:54.960: %LWAPP-3-VENDOR_PLD_VALIDATE_ERR: spam_lrad.c:11913 Validation of SPAM_VENDOR_SPECIFIC_PAYLOAD(185) with length=9 failed - AP cc:16:7e:a2:03:80
I have the same issue as decribed in bug id CSCvi34340, but my country code is Germany.
My AP is AIR-AP2702I-UXZBLK
My WLC is 2504 with 11 AP support license and software version 8.5.135.0.
Thanks a lot for helping,
Sergej
