AP Signal
Victor Fabian
I want to reduce the AP's signal . Will the APs reboot to apply the new change ?
Thank you
Vic
gamccall
Level 4
Level 4
No, you can change power on the fly.
Gamccall is on the money again!
I would like to mention if you change channels you could see a client have a short "blip".
But you are good playing with the power....
