Bridge mode of controller base ap
CHUN FAI LAW
I have testes two standalone ap is able to connect thorugh root-bridge mode and non-bridge mode, but when i try to the non-root bridge ap to controller base ap with bridge mode enable is fail, is there anyone can provide some suggestion?
Ras good reply my friend +5.
Chun -- Correct if you put it into workgroup bridge mode it will connect. You mentioned you were in root / non-root. It will not if thats the case.
__________________________________________________________________________________________
‎"I'm in a serious relationship with my Wi-Fi. You could say we have a connection."
7 Replies 7
George Stefanick
Hi Chun
Good question and folks often get this confused. You aren't alone ..
Root and non-root are for aps in standalone also called autonomous mode. You can not bridge a non-root ap to a controller ap.
If you want to do bridging with a wlc you need to configure your aps in mesh mode.
Does that help ?
Hi Chun,
There is a way around as long as you configure non-root AP as WGB (station role work group-bridge). Then you should be able it to connect to controller based AP.  Here how I did this for a testing purpose
http://mrncciew.com/2013/06/16/unified-ap-wgb-with-multiple-vlan/
Rasika
it seems a useful post for this kind of connection. Thank you very much!!
No worries.. as long as it helps you
hi George,
I have try to creat a wlan in contorller with ssid:bridge, it work finally.
That autonomous ap i config as below,
hostname non-root-bridge
dot11 ssid bridge
authentication op
infrastructure-ssid
exit
int dot1 0
ssid bridge
station-role non-root bridge / workgroup-bridge
no shut
Thanks George..
