03-07-2014 08:58 AM - edited 07-05-2021 12:22 AM
We are about the deploy 2 WLCs 5508 in the DMZ to ensure traffic on mobile devices will be going thru Internet directly.
Between the Intranet and the DMZ we have a firewall, we did a lot of tests and the following is occuring :
normal pings between Intranet <> DMZ are fine
epings between Intranet <> DMZ are fine
mpings are not working between Intranet <> DMZ.
We checked carefully that the firewall is having IP Protocol 97 and UDP 16666 open but even with that in place mpings are still failing.
We opened completely the firewall during a couple of minutes same problem.
We checked the logs and we had the impression that IP Protocol 97 was clearly visible on the logs but not UDP.
I verified that WLCs in Intranet and / or DMZ are not using ACLs and it is not the case.
A debug mobility keep-alive show the same, IP Protocol 97 is ok but not UDP 16666...
So my anchor stays at Control path Down on both ends.
We don't have also ACLs on the switches in between...
We are running out of ideas here and I would be very glad to have more information how to process further on that...
Thanks for your help.
Update 14.03.2014 : I finally found the solution, it seems that when the network route is defined to widely this could affect the management interfaces during the tunnel mounting. This is not normal and not properly documented, usually network should serve only service port as the default gateway option is not configurable. Cisco will try to add this in the TAC knowledge bade for helping other people facing the same to spare some time in troubleshooting
in my case i simply changed the route to be really specific and the tunnel mounted immediately.
but thanks all for the suggestions and support provided.
03-07-2014 09:17 AM
Delete the mobility group from both WLC's and add it back on. Sometimes that is the issue especially if the FW is wide open.
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
03-07-2014 09:57 AM
Hi Scott,
Thanks for your fast reply,
We agree that the Default Mobility Domain Name should be different in Intranet WLCs and in DMZ WLCs for security reasons ?
It is just important to create the anchor by specifying the Domain name configured on the destination controller ?
03-07-2014 09:59 AM
The mobility domain name should be different... best practice and you should specify the mobility domain name when creating the anchor.
Scott
03-07-2014 10:01 AM
Ok I removed the anchor on both and recreated it, but it is the same :-(
Control path down
I try also to reboot the WLC's in the DMZ but same problem,
Would be something else to check in order to mount up the EoIP tunnel properly?
03-07-2014 10:10 AM
The only way to test if the FW is dropping the traffic is to mount the WLC in the inside for testing and create your mobility anchor. If this works, then something is dropping UDP 16666/16667.
Post your show mobility summary from both
Scott
03-07-2014 10:17 AM
Ok this was my thought maybe
I realized something else,
In the DMZ the WLCs are connected to switches.
We have a trunk (2 Vlans configured one for management and one for users traffic) and WLCs are in LAG mode. 4 interfaces on 8 are connected currently.
We use a subnet like 172.21.1.xxx for the management interfaces.
The default GW of the management interface is the firewall.
But since a couple of hours the mobility anchor is instead of up / up is Data Path Down,
As the subnet is the same they should not use the default GW between them, why now the Data Path is down...
Is there anything special to verify / configure on the switches ?
Here the output :
DMZ WLC 1 = 172.21.2.6 :
Mobility Architecture ........................... Flat
Mobility Protocol Port........................... 16666
Default Mobility Domain.......................... DMZ_SG_MOBILITY
Multicast Mode .................................. Disabled
Mobility Domain ID for 802.11r................... 0xe8e1
Mobility Keepalive Interval...................... 10
Mobility Keepalive Count......................... 3
Mobility Group Members Configured................ 3
Mobility Control Message DSCP Value.............. 0
Controllers configured in the Mobility Group
 MAC Address        IP Address       Group Name                        Multicast IP     Status
 70:81:05:1f:e4:40  10.136.10.36     SG_MOBILITY                       0.0.0.0          Control Path Down
 78:da:6e:8a:ee:20  172.21.2.5       DMZ_SG_MOBILITY                   0.0.0.0          Data Path Down
 78:da:6e:8b:14:60  172.21.2.6       DMZ_SG_MOBILITY                   0.0.0.0          Up
Intranet WLC 1 = 10.136.10.36 :
(Cisco Controller) >show mobility summary
Default Mobility Domain.......................... SG_MOBILITY
Mobility Domain ID for 802.11r................... 0xd9f7
Mobility Group Members Configured................ 5
 70:81:05:1f:e4:40  10.136.10.36     SG_MOBILITY                       0.0.0.0          Up
 78:da:6e:8b:14:60  172.21.2.6       DMZ_SG_MOBILITY                   0.0.0.0          Control Path Down
 cc:ef:48:0c:85:80  10.136.10.32     SG_MOBILITY                       0.0.0.0          Up
03-11-2014 12:34 AM
03-07-2014 10:29 AM
mping verify the control path between two WLC. It use the UDP 16666 & in your case it is not working & hence control path is down.
eping verify the data path between two WLCs & uses EoIP. Since it is working for you no issue with EoIP.
Pls post the output of "show mobility summary" & "show sysinfo" of both WLCs to see any config issues.
Rasika
**** Pls rate all useful responses ****
03-07-2014 10:34 AM
show mobility summary is posted above, here the show sysinfo :
Intranet WLC 1 10.136.10.36 :
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.4.100.0
Bootloader Version............................... 1.0.1
Field Recovery Image Version..................... 6.0.182.0
Firmware Version................................. FPGA 1.3, Env 1.6, USB console 1.27
Build Type....................................... DATA + WPS
System Name...................................... xxxxx
System Location.................................. xxxx
System Contact................................... xxxxx
System ObjectID.................................. 1.3.6.1.4.1.9.1.1069
Redundancy Mode.................................. Disabled
IP Address....................................... 10.136.10.36
Last Reset....................................... Software reset
System Up Time................................... 369 days 10 hrs 47 mins 44 secs
System Timezone Location......................... (GMT +1:00) Amsterdam, Berlin, Rome, Vienna
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... Multiple Countries:AU,BE,CH,CN,DE,FR,GB,HK,IT,J2,MX,NL,RU,SG,TH,TR,US,ZA
--More-- or (q)uit
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +40 C
External Temperature............................. +20 C
Fan Status....................................... OK
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 5
Number of Active Clients......................... 128
Memory Current Usage............................. Unknown
Memory Average Usage............................. Unknown
CPU Current Usage................................ Unknown
CPU Average Usage................................ Unknown
Burned-in MAC Address............................ 70:81:05:1F:E4:40
Power Supply 1................................... Present, OK
Power Supply 2................................... Present, OK
Maximum number of APs supported.................. 500
DMZ WLC 1 172.21.2.6 :
Product Version.................................. 7.4.110.0
Bootloader Version............................... 1.0.18
Field Recovery Image Version..................... 7.6.95.16
Firmware Version................................. FPGA 1.7, Env 1.8, USB console 2.2
IP Address....................................... 172.21.2.6
System Up Time................................... 0 days 1 hrs 54 mins 0 secs
Configured Country............................... CH  - Switzerland
--More-- or (q)uit
Internal Temperature............................. +45 C
External Temperature............................. +33 C
State of 802.11b Network......................... Disabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 0
Number of Active Clients......................... 0
Burned-in MAC Address............................ 78:DA:6E:8B:14:60
Maximum number of APs supported.................. 12
Thanks for your support :-)
03-07-2014 10:48 AM
Thanks for the inputs, configs looks ok to me.
Does all these WLCs having same virtual interface IP ?
Though it may not related, I can see lots of conflicting regulatory domain country codes configured on your DMZ controller ? Does this something you purposely configured ?
On a side note the software version (7.4.100.0) you are running on intranet WLCs are too buggy & recommend you to upgrade them to 7.4.121.0. Upgrade FUS to 1.9.0.0 as well.
Rasika
03-07-2014 10:58 AM
In fact they were having the same virtual IP but I changed it, I just reverted back for all.
Intranet WLCs is serving several countries, so yes it is on purpose that we have several regulatory domains :-)
Thanks for the tip about the version, how do you upgrade FUS by the way ?
Thank you
03-07-2014 11:11 AM
Hi Holzhirt1,
PFB link for FUS upgrade.
Expect a downtime of 30-40 mins.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.pdf
Ashish.
03-07-2014 11:12 AM
Is there any difference made by that ? You should have same virtual IP address in order to mobility to work properly. So make sure it is same everywhere.
It is not ideal configuring conflicting regulatory domain country codes in single WLC (could impact channels, power levels for certain APs, sometime certain AP radio band won't come up). Best would be having unique controller to serve same regulatory domain country code APs.
Here is the link to FUS 1.9.0.0 upgrade. Keep note that this will take 30-40min of downtime to your wireless & get a sufficient outage window to do this.
http://www.cisco.com/c/en/us/td/docs/wireless/controller/release/notes/fus_rn_OL-31390-01.html
In the below thread I have posted CLI commands for this upgrade with respect to 2504. You can follow that with required image downloads for 5508
https://supportforums.cisco.com/thread/2270290
Rasika
03-07-2014 11:25 AM
Now I have same virtual IPs on all but it is the same,
mpings are not going thru....
I will try again to remove mobility groups and re-create it...
thanks for the links Rasika
