05-04-2009 07:22 AM - edited 07-03-2021 05:32 PM
Here is my problem.
I recently installed a 1130AG wap in one of our remote offices. There are three computers in this office, all wireless ofcourse.
Two of the three computers stay connected, and one drops every few minutes and connects back up. I have switch the computer out with another computer (of the same kind) and still the same result.
The two computers that are working are the same.
The ones that arent is a tablet PC. I just thought it might have been the adapter, but since there is a new tablet, its still dropping the connection.
Is there anything I can try?
HELP!!!!
p.s. This is what the event log says (remember there is only one WAP on our floor.) However there are different businesses in this building...
Interface Dot11Radio0, Deauthenticating Station 0014.a553.25a3 Reason: Disassociated because sending station is leaving (or has left) BSS
05-04-2009 07:36 AM
Look at the device's firmware and upgrade it to the latest manufacture supported version for the tablet. That will usually fix the issue.
05-04-2009 09:48 AM
I agree with fella5. You may also try relocating the device in question to see if you get a better signal and/or check for interference in that particular area
05-04-2009 09:54 AM
how can i check for Interference?
I get god signal all across the rooms...
I will upgrade the BIOS today.
05-04-2009 09:56 AM
Not the bios... the wireless driver in the tablet. If you have no issues with other devices except for the tablet, then its most likely not interference. You can use netstumbler to see what is out there and its free.
05-04-2009 10:56 AM
Actually,
I put the WAP on channel 1 rather than channel 3 and havent lost contact with that Tablet for 2 hours now since i made the change. Can changing from 1 to 3 really make a difference?
This is good so now i wont have to do any upgrades!!!
05-04-2009 11:36 AM
You should only use non-overlapping channels 1,6 & 11 (in US) channel 3 conflicts with 1 & 6 frequency ranges.
Yes, it can make a huge difference depending upon your environment.
