How to check how mang users can access Wireless network concurrently with one credential?
DuJin0509
Dear everyone,
I want to check how many WIFI users can access Wireless network concurremtly utilize one credential ?
I can not use GUI , so please kindly share the CLI command to approach.
Thank you very much.
Rasika Nayanajith
Is this WLC managed AP ? If so you can try below
(WLC) >show client username <user_name>
Rasika
*** Pls rate all useful responses ***
5 Replies 5
Rasika Nayanajith
Rasika
Hello Rasika,
I means I want to know if it is possible to verify how many users could utilize one credential concurrently even if no user real access the network, just use the cli to verify the max login value, like CIsco easyvpn we could define how many user could login the same time with one credential.
Because a customer complain his IPAD and IPHONE can not authenticate successful, so I suspect the max login number count is 1.(his laptop has login with his credential already)
> show netuser summary
Maximum logins allowed for a given username ........Unlimited
This example shows how to display detailed information on the specifies network user:
> show netuser detail john10
username........................................... abc
WLAN Id............................................. Any
Lifetime............................................ Permanent
Description......................................... test user
hajia
Hi DuJin,
Have you tried
Max Concurrent Logins for a user name1
WLC -- Security -- AAA --- User Login Policies
If you set it to 0, means no limition.
https://supportforums.cisco.com/discussion/11588876/wlc-5508-cannot-have-similar-user-logged-twice
