Is EAP-TLS and Fast Secure Roaming possible (CCKM) on WDS AP ?
Mohamed Hamid
Hi there
I have set-up a Cisco AP1142n as a WDS AP and my SSID is using EAP-TLS certificate based authentication.
My users rely on a VPN connection whilst connected to the SSID.
I am finding that the current roaming functions are not good enough and that VPN connections are disconnecting when roaming.
I am looking at the FSR (Fast Secure Roaming) feature however having trouble setting it up with EAP-TLS  when using CCKM for key authentication...
Is this something that is possible?
0 Replies 0
