Mac-Address Filtering using more than one SSID
pacsniffing
Hey All,
I've been asked to configure mac-address filtering on our WLC 4402 and it was basically straight forward.  however i noticed that in creating the filter you can only choose 1 SSID or the other option would be to choose all?  My question then is what happens if i need a user one 2 specific SSIDs?  can i create separate filters for each SSID but using the same mac?
Scott Fella
No you only can have one MAC address filter. You should only have a device associated to one SSID. So as you know, you either choose one WLAN or choose all.
-Scott
