Need help-WLC4402. Both primary and backup images not found
ajtm
I didn't find any procedure to upgrade from bootloader.
1. Run primary image (version Not Found)
2. Run backup image (version Not Found) (active)
3. Manually update images
4. Change active boot image
5. Clear Configuration
andrew.prince
Level 10
Level 10
Antonio,
The only way to recover this WLC is with the TAC - you need to up load specific files, only they will give them to you.
HTH>
