Problem with AP: CSCwk71043 - Assoc Resp failed
ba so
Community Member
CSCwk71043 - Assoc Resp failed due to CLIENT_DEL_DRIVER_ADDING_ENTRY_IN_FIRMWARE_FAILED
The problem is becoming more and more frequent. Is there already a possible permanent solution/update?
Symptom: Assoc Resp failed due to CLIENT_DEL_DRIVER_ADDING_ENTRY_IN_FIRMWARE_FAILED *** RSN ERROR: Received a data frame when no keys are plumbedDOT11_DRV[1]: wcp/RadDrv1 :: Dot11BaseDriver vendor_set_80211_priv ioctl WL_IOCTL_SET_MGMT_SEND failed for apr1v0 error Unknown error 1306 DS Mgmt Assoc Resp 30 failed, fail reason CLIENT_DEL_DRIVER_ADDING_ENTRY_IN_FIRMWARE_FAILED
Conditions: during normal operation
Workaround: AP rebooting
Further Problem Description: na
Mark Elsen
  - @ba so         Are you using a controller ? If so , which type ?
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
ba so
Community Member
WLC:
2 x C9800-L-F-K9 (RMI+RP)
Cisco IOS XE Software, Version 17.12.05
The problem occurs on APs:
AIR-AP2802E-E-K9
AP Running Image : 17.12.5.41
  - @ba so             Have a try with 17.15.4b
  M.
       Beauty and terror
      Just keep going
       No feeling is final
