cancelar
Mostrando los resultados de
Buscar en lugar de
Quiere decir:
Visitas
ÚTIL
Respuestas
problems in AP
jecheverrif
Frequent Visitor
Frequent Visitor
Hello, I have a Cisco 3504 controller and I have 26 AIR-AP2802I-A-K9 on it, at the moment I want to change one of these for a CW9166I-A, I have it connected and the controller does not recognize it
1 SOLUCIÓN ACEPTADA
Soluciones aceptadas
balaji.bandi
WLC 3504 what Code running, for the Cat9K ap to join you need minimum code to be available.
https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
BB
Ver la solución en mensaje original publicado
2 RESPUESTAS 2
balaji.bandi
BB
In the controller I try to add it with the command config ap add <MAC addr> <port> [enable/disable] <ip-addr>
