Some Wireless Users are not getting IP
Hi All,
I have setup which consists of WLC 9800-40 and catalyst 9136 APs. Some users are able to get the IP address from the DHCP server whereas some users are unable to get the IP Addresses. Please need your suggestions
2 Accepted Solutions
Mark Elsen
 - Have a checkup analysis and review of the WLC 9800-40 configuration with the CLI command show tech wireless ; feed the output into : Wireless Config Analyzer
         Use these  recommended setup(s) for DHCP : https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9800-series-wireless-controllers/guide-c07-743627.html#DHCPbridgingandDHCPrelay
   - If problem persists use client debugging according to https://logadvisor.cisco.com/logadvisor/wireless/9800/9800ClientConnectivity   , you can have client debugs (so called RadioActive Traces) analyzed with : https://cway.cisco.com/wireless-debug-analyzer
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Thanks to all, i checked the Radio Active trace for one User (MAC address) and i found the user was timeout in IP Learn. After troubleshooting the issue i found that the subnet mask configured under SVI was different from the subnet mask inside the DHCP pool. After fixing subnet mask under SVI, the issue was fixed.
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
Leo Laohoo
Maybe the IP address pool is not large enough.
Try and clear the address pool.
