05-25-2020 09:12 AM
Hi all,
I was trying to use YDK openconfig_network_instance python modules to pass the redistribution of routes of BGP IOS-XR router, the import-policy field apparently doesn't recognize the already defined policies in the IOS-XR
Could anyone kindly help me find what parameters I'm missing?
Below the steps I've tried:
from ydk.models.openconfig import openconfig_network_instance as oc_netins from ydk.models.openconfig.openconfig_interfaces import Interfaces as oci from ydk.models.openconfig.openconfig_network_instance_types import DEFAULTINSTANCE,L3VRF from ydk.models.openconfig.openconfig_types import IPV4 from ydk.models.openconfig.openconfig_policy_types import BGP, DIRECTLYCONNECTED from ydk.models.openconfig.openconfig_routing_policy import DefaultPolicyType from ydk.services import CRUDService from ydk.providers import NetconfServiceProvider from ydk.models.openconfig import openconfig_bgp as oc_bgp from ydk.models.openconfig import openconfig_bgp_types as oc_bgp_types netins_s = oc_netins.NetworkInstances() netins = netins_s.NetworkInstance() table_connection = netins.table_connections.TableConnection() table_connection.src_protocol=DIRECTLYCONNECTED() table_connection.config.src_protocol=DIRECTLYCONNECTED() table_connection.dst_protocol=BGP() table_connection.config.dst_protocol=BGP() table_connection.address_family=IPV4() table_connection.config.address_family=IPV4() table_connection.config.import_policy = "ROUTE-POLICY" netins.table_connections.table_connection.append(table_connection) bgp_proto = netins.protocols.Protocol() bgp_proto.name = "default" bgp_proto.config.name = "default" bgp_proto.identifier = BGP() bgp = bgp_proto.bgp bgp.global_.config.as_ = 65000 afi_safi = bgp.global_.afi_safis.AfiSafi() afi_safi.afi_safi_name = oc_bgp_types.IPV4UNICAST() afi_safi.config.afi_safi_name = oc_bgp_types.IPV4UNICAST() afi_safi.config.enabled = True bgp.global_.afi_safis.afi_safi.append(afi_safi) netins.protocols.protocol.append(bgp_proto) provider = NetconfServiceProvider(address=ipaddress, username=user, password=password) crud = CRUDService() crud.create(provider, netins)
Apparently the defined route policy specified in the table connections doesn't match the route policy defined in the device
Traceback (most recent call last): File "<stdin>", line 1, in <module> File "/usr/local/lib/python3.7/site-packages/ydk/errors/error_handler.py", line 112, in helper return func(self, provider, entity, *args, **kwargs) File "/usr/local/lib/python3.7/site-packages/ydk/services/crud_service.py", line 49, in create return _crud_update(provider, entity, self._crud.create) File "/usr/local/lib/python3.7/site-packages/ydk/services/crud_service.py", line 70, in _crud_update return crud_call(provider, entity) File "/usr/local/lib/python3.7/site-packages/ydk/types/py_types.py", line 303, in get_name_leaf_data leaf.set(value) File "/usr/local/lib/python3.7/site-packages/ydk/types/py_types.py", line 80, in set raise _YModelError("Invalid value '{}' in '{}'".format(other, self.leaf_name)) ydk.errors.YModelError: Invalid value 'ROUTE-POLICY' in 'import-policy'
Note that ROUTE-POLICY was previously defined on the device for the sake of testing the redistribution config
! route-policy ROUTE-POLICY pass end-policy !
If I try the same without specifying any import policy in the table connections section the RPC is accepted but the BGP configuration will not contain the desired redistribution
! router bgp 65000 bgp router-id 10.1.1.1 address-family ipv4 unicast ! !
2020-05-25 16:03:39,493 - ydk - INFO - ============= Sending RPC to device ============= <rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><edit-config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"> <target> <candidate/> </target> <config><network-instances xmlns="http://openconfig.net/yang/network-instance" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0"> <network-instance nc:operation="merge"> <name>default</name> <config> <name>default</name> </config> <table-connections> <table-connection> <src-protocol xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:DIRECTLY_CONNECTED</src-protocol> <dst-protocol xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:BGP</dst-protocol> <address-family xmlns:oc-types="http://openconfig.net/yang/openconfig-types">oc-types:IPV4</address-family> <config> <src-protocol xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:DIRECTLY_CONNECTED</src-protocol> <address-family xmlns:oc-types="http://openconfig.net/yang/openconfig-types">oc-types:IPV4</address-family> <dst-protocol xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:BGP</dst-protocol> </config> </table-connection> </table-connections> <protocols> <protocol> <identifier xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:BGP</identifier> <name>default</name> <config> <name>default</name> </config> <bgp> <global> <config> <as>65000</as> </config> <afi-safis> <afi-safi> <afi-safi-name xmlns:oc-bgp-types="http://openconfig.net/yang/bgp-types">oc-bgp-types:IPV4_UNICAST</afi-safi-name> <config> <afi-safi-name xmlns:oc-bgp-types="http://openconfig.net/yang/bgp-types">oc-bgp-types:IPV4_UNICAST</afi-safi-name> <enabled>true</enabled> </config> </afi-safi> </afi-safis> </global> </bgp> </protocol> </protocols> </network-instance> </network-instances> </config> </edit-config> </rpc> 2020-05-25 16:03:39,522 - ydk - INFO - ============= Received RPC from device ============= <?xml version="1.0"?> <rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="3"> <ok/> </rpc-reply> 2020-05-25 16:03:39,522 - ydk - INFO - Executing 'commit' RPC 2020-05-25 16:03:39,522 - ydk - INFO - ============= Sending RPC to device ============= <rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><commit xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"/> </rpc> 2020-05-25 16:03:40,844 - ydk - INFO - ============= Received RPC from device ============= <?xml version="1.0"?> <rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="4"> <ok/> </rpc-reply> 2020-05-25 16:03:40,844 - ydk - INFO - Operation succeeded
My system info
GNU bash, version 5.0.3(1)-release python Python 3.7.7 (default, Apr 21 2020, 14:26:12) [GCC 8.3.0] on linux pip list Package Version ----------------------- ----------- alabaster 0.7.12 Babel 2.8.0 bleach 3.1.4 certifi 2020.4.5.1 cffi 1.14.0 chardet 3.0.4 cryptography 2.9.2 docutils 0.16 gitdb 4.0.4 GitPython 3.1.0 idna 2.9 imagesize 1.2.0 importlib-metadata 1.6.0 jeepney 0.4.3 Jinja2 2.11.2 keyring 21.2.0 MarkupSafe 1.1.1 pip 20.0.2 pkginfo 1.5.0.1 pyang 1.6 pybind11 2.5.0 pycparser 2.20 Pygments 2.6.1 pytz 2019.3 readme-renderer 26.0 requests 2.23.0 requests-toolbelt 0.9.1 rstr 2.2.6 SecretStorage 3.1.2 setuptools 46.1.3 six 1.14.0 smmap 3.0.2 snowballstemmer 2.0.0 Sphinx 1.4a1 sphinx-rtd-theme 0.1.9 tqdm 4.45.0 twine 3.1.1 urllib3 1.25.9 webencodings 0.5.1 wheel 0.34.2 ydk 0.8.4 ydk-models-cisco-ios-xr 6.6.3 ydk-models-ietf 0.1.5.post2 ydk-models-openconfig 0.1.6.post1 zipp 3.1.0 Cisco IOS-XR version Cisco IOS XR Software, Version 6.6.2
Solved! Go to Solution.
05-25-2020 10:17 PM
From what I can see, the YDK worked fine this time.
There might be some limitations in specific implementation of openconfig Yang models in IOS XR. Therefore I suggest you to talk to IOS XR software development team, which knows programmability implementation details.
05-25-2020 11:30 AM
The following line in your script is incorrect:
The 'import_policy' is instance of YLeafList class and must be handled differently:
table_connection.config.import_policy.append("ROUTE-POLICY")
I also would suggest update your openconfig package to new version 0.1.8; simply:
pip install -U ydk-models-openconfig
05-25-2020 01:03 PM
Thanks @yangorelik !! I've upgraded and implemented as you recommeded, that solves the import policy part, but still for some reason the IOS-XR device that I'm pushing the table connections still won't reflect that table connection as desired ... even after the RPC call returns ok status
By this neconf message:
2020-05-25 19:50:50,016 - ydk - INFO - ============= Sending RPC to device ============= <rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><edit-config xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"> <target> <candidate/> </target> <config><network-instances xmlns="http://openconfig.net/yang/network-instance" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0"> <network-instance nc:operation="merge"> <name>default</name> <config> <name>default</name> </config> <table-connections> <table-connection> <src-protocol xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:DIRECTLY_CONNECTED</src-protocol> <dst-protocol xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:BGP</dst-protocol> <address-family xmlns:oc-types="http://openconfig.net/yang/openconfig-types">oc-types:IPV4</address-family> <config> <src-protocol xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:DIRECTLY_CONNECTED</src-protocol> <address-family xmlns:oc-types="http://openconfig.net/yang/openconfig-types">oc-types:IPV4</address-family> <dst-protocol xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:BGP</dst-protocol> <import-policy>ROUTE-POLICY</import-policy> </config> </table-connection> </table-connections> <protocols> <protocol> <identifier xmlns:oc-pol-types="http://openconfig.net/yang/policy-types">oc-pol-types:BGP</identifier> <name>default</name> <config> <name>default</name> </config> <bgp> <global> <config> <as>65000</as> <router-id>10.1.1.1</router-id> </config> <afi-safis> <afi-safi> <afi-safi-name xmlns:oc-bgp-types="http://openconfig.net/yang/bgp-types">oc-bgp-types:IPV4_UNICAST</afi-safi-name> <config> <afi-safi-name xmlns:oc-bgp-types="http://openconfig.net/yang/bgp-types">oc-bgp-types:IPV4_UNICAST</afi-safi-name> <enabled>true</enabled> </config> </afi-safi> </afi-safis> </global> </bgp> </protocol> </protocols> </network-instance> </network-instances> </config> </edit-config> </rpc> 2020-05-25 19:50:50,040 - ydk - INFO - ============= Received RPC from device ============= <?xml version="1.0"?> <rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="53"> <ok/> </rpc-reply> 2020-05-25 19:50:50,041 - ydk - INFO - Executing 'commit' RPC 2020-05-25 19:50:50,041 - ydk - INFO - ============= Sending RPC to device ============= <rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><commit xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"/> </rpc> 2020-05-25 19:50:51,285 - ydk - INFO - ============= Received RPC from device ============= <?xml version="1.0"?> <rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="54"> <ok/> </rpc-reply>
I was expecting that 'redistribute connected route-policy ROUTE-POLICY' would appear under the ipv4 unicast AFI but instead still looks like this:
05-25-2020 10:17 PM
05-26-2020 08:54 AM
Did not notice this on the logs before, openconfig deviations for ios-xr are not parsed through from the little i understand:
2020-05-26 15:43:19,969 - ydk - ERROR - Data is invalid according to the yang model. Libyang error: Reached limit (65535) for storing typedefs. 2020-05-26 15:43:19,970 - ydk - ERROR - Data is invalid according to the yang model. Libyang error: Module "cisco-xr-openconfig-network-instance-deviations" parsing failed.
which seems ignored and continues on with configuration, but it can be seen by looking at the actual yang file of the openconfig ios-xr-deviations that indeed openconfig table-connections are not supported :(
deviation "/oc-netinst:network-instances/oc-netinst:network-instance/oc-netinst:table-connections/oc-netinst:table-connection" { deviate not-supported; }
Thanks for the help
05-26-2020 10:22 AM
Regarding error messages. That issue was spotted previously. The details could be viewed here. In short, the Libyang has limitation of 255 deviation statements per module. Apparently number of such statements exceeds 255.
The only known workaround for this issue is manual altering of deviation file in the temporary repository by deleting deviation statements, which are not of importance for your application.
