关于ip traffic 中bad hop count的问题
5201314wdmcwfnh
问题如下:
两台cisco 3750E做的堆叠。IOS版本如下:
core-down#show version
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 12.2(55)SE3,
RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Thu 05-May-11 15:40 by prod_rel_team
Image text-base: 0x00003000, data-base: 0x02800000
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTW
ARE (fc1)
core-down uptime is 38 weeks, 1 day, 19 hours, 19 minutes
System restarted at 00:22:52 beijing Sun Oct 22 2017
System image file is "flash:/c3750e-universalk9-mz.122-55.SE3/c3750e-universalk9
-mz.122-55.SE3.bin"
目前的问题是:
我输show ip traffice后,在IP statistics下面,
bad hop count和not a gateway 这两项不正常。每秒钟都会增加几十个计数。
core-down#show ip traffic
IP statistics:
Rcvd: 432317279 total, 97435362 local destination
1165 format errors, 1339 checksum errors, 311477316 bad hop count
79 unknown protocol, 23001384 not a gateway
0 security failures, 0 bad options, 43 with options
Opts: 0 end, 0 nop, 0 basic security, 0 loose source route
0 timestamp, 0 extended security, 0 record route
0 stream ID, 0 strict source route, 43 alert, 0 cipso, 0 ump
0 other
请教一下大家,这种现象一般会是哪些情况会造成此影响?有没有什么解决办法?
-------------------------------------------------------------------最新进展--------------------------------------------------------------------
我通过命令:debug ip error detail ,将有错误的包信息从日志当中复制出来(以下是debug信息):
从debug信息来看,应该是有大量的UDP包导致 bad hop count 和not a gateway 快速增加。
从UDP的内容来看,LLMNR,NBNS 大量充斥网络。
问一下大家这种问题怎么处理啊??
还有就是很多到目标地址:192.168.1.1这个是什么鬼流量。我们内网都没有192.168.1这个网段。。。。
.Jul 16 13:53:29.553 beijing: IP: s=192.168.22.23 (Vlan22), d=192.168.22.255, le
n 78, dispose udp.noport
.Jul 16 13:53:29.553 beijing: UDP src=137, dst=137
.Jul 16 13:53:29.553 beijing: IP: s=10.104.143.101 (Vlan52), d=192.168.1.1, len
57, dispose ip.hopcount
.Jul 16 13:53:29.561 beijing: UDP src=45504, dst=53
.Jul 16 13:53:29.561 beijing: IP: s=192.168.22.15 (Vlan22), d=224.0.0.252, len 5
0, dispose ip.hopcount
.Jul 16 13:53:29.561 beijing: UDP src=63026, dst=5355
.Jul 16 13:53:29.561 beijing: UDP src=58093, dst=5355
.Jul 16 13:53:29.561 beijing: UDP src=61453, dst=5355
8, dispose ip.hopcount
.Jul 16 13:53:29.561 beijing: UDP src=52709, dst=5355
.Jul 16 13:53:29.561 beijing: IP: s=172.23.128.2 (Vlan100), d=224.0.0.18, len 40
, dispose ip.notgateway, proto=112
.Jul 16 13:53:29.595 beijing: IP: s=192.168.22.43 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:29.595 beijing: UDP src=137, dst=137
.Jul 16 13:53:30.658 beijing: IP: s=10.100.87.103 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:30.658 beijing: UDP src=40900, dst=53
.Jul 16 13:53:30.951 beijing: IP: s=10.104.28.102 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:30.951 beijing: UDP src=48810, dst=53
.Jul 16 13:53:30.951 beijing: IP: s=10.104.141.104 (Vlan52), d=192.168.1.1, len
65, dispose ip.hopcount
.Jul 16 13:53:30.951 beijing: UDP src=52432, dst=53
.Jul 16 13:53:30.951 beijing: IP: s=10.102.51.101 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:30.951 beijing: UDP src=55162, dst=53
.Jul 16 13:53:30.951 beijing: IP: s=10.6.47.101 (Vlan52), d=192.168.1.1, len 57,
dispose ip.hopcount
.Jul 16 13:53:30.951 beijing: UDP src=40900, dst=53
.Jul 16 13:53:30.951 beijing: IP: s=192.168.23.110 (Vlan23), d=192.168.23.255, l
en 78, dispose udp.noport
.Jul 16 13:53:30.951 beijing: UDP src=137, dst=137
.Jul 16 13:53:30.951 beijing: IP: s=10.104.107.102 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:30.951 beijing: UDP src=57271, dst=53
.Jul 16 13:53:30.960 beijing: IP: s=10.101.131.104 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:30.960 beijing: UDP src=50517, dst=53
.Jul 16 13:53:30.960 beijing: IP: s=10.103.58.101 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:30.960 beijing: UDP src=59080, dst=53
.Jul 16 13:53:30.960 beijing: IP: s=10.100.136.102 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:30.960 beijing: UDP src=39400, dst=53
.Jul 16 13:53:30.960 beijing: IP: s=192.168.22.15 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:30.960 beijing: UDP src=137, dst=137
.Jul 16 13:53:30.960 beijing: IP: s=10.102.51.102 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:30.960 beijing: UDP src=53956, dst=53
.Jul 16 13:53:30.960 beijing: IP: s=10.105.14.103 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:30.960 beijing: UDP src=41290, dst=53
.Jul 16 13:53:30.968 beijing: IP: s=10.100.7.101 (Vlan52), d=192.168.1.1, len 57
.Jul 16 13:53:30.968 beijing: UDP src=48211, dst=53
.Jul 16 13:53:30.968 beijing: IP: s=192.168.22.43 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:30.968 beijing: UDP src=137, dst=137
.Jul 16 13:53:30.968 beijing: IP: s=10.104.128.103 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:30.968 beijing: UDP src=59412, dst=53
.Jul 16 13:53:30.968 beijing: IP: s=10.104.145.103 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:30.968 beijing: UDP src=44753, dst=53
.Jul 16 13:53:30.968 beijing: IP: s=192.168.23.110 (Vlan23), d=192.168.23.255, l
.Jul 16 13:53:30.968 beijing: IP: s=192.168.22.15 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:30.968 beijing: IP: s=172.23.128.2 (Vlan100), d=224.0.0.18, len 40
.Jul 16 13:53:30.968 beijing: IP: s=192.168.19.206 (Vlan19), d=224.0.0.251, len
118, dispose ip.notgateway
.Jul 16 13:53:30.968 beijing: UDP src=5353, dst=5353
.Jul 16 13:53:31.495 beijing: IP: s=10.104.20.101 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:31.495 beijing: UDP src=38316, dst=53
.Jul 16 13:53:31.495 beijing: IP: s=10.104.20.102 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:31.495 beijing: UDP src=38322, dst=53
.Jul 16 13:53:31.495 beijing: IP: s=192.168.22.43 (Vlan22), d=224.0.0.252, len 6
1, dispose ip.hopcount
.Jul 16 13:53:31.495 beijing: UDP src=56532, dst=5355
.Jul 16 13:53:31.495 beijing: IP: s=192.168.7.223 (Vlan2), d=224.0.0.252, len 51
.Jul 16 13:53:31.504 beijing: UDP src=64733, dst=5355
.Jul 16 13:53:31.504 beijing: IP: s=192.168.7.223 (Vlan2), d=224.0.0.252, len 51
.Jul 16 13:53:31.504 beijing: UDP src=56422, dst=5355
.Jul 16 13:53:31.504 beijing: IP: s=192.168.21.86 (Vlan21), d=224.0.0.252, len 5
.Jul 16 13:53:31.504 beijing: UDP src=64901, dst=5355
.Jul 16 13:53:31.504 beijing: IP: s=192.168.22.43 (Vlan22), d=224.0.0.252, len 6
.Jul 16 13:53:31.504 beijing: UDP src=56532, dst=5355
.Jul 16 13:53:31.546 beijing: IP: s=172.23.128.2 (Vlan100), d=224.0.0.18, len 40
.Jul 16 13:53:31.554 beijing: IP: s=10.104.176.101 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:31.554 beijing: UDP src=49860, dst=53
.Jul 16 13:53:31.571 beijing: IP: s=192.168.19.206 (Vlan19), d=224.0.0.251, len
.Jul 16 13:53:31.571 beijing: UDP src=5353, dst=5353
.Jul 16 13:53:31.571 beijing: IP: s=192.168.22.43 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:31.571 beijing: UDP src=137, dst=137
.Jul 16 13:53:31.579 beijing: IP: s=10.4.60.102 (Vlan52), d=192.168.1.1, len 57,
dispose ip.hopcount
.Jul 16 13:53:31.579 beijing: UDP src=38109, dst=53
.Jul 16 13:53:32.416 beijing: IP: s=192.168.21.86 (Vlan21), d=192.168.21.255, le
.Jul 16 13:53:32.416 beijing: UDP src=137, dst=137
.Jul 16 13:53:32.592 beijing: IP: s=10.2.76.102 (Vlan52), d=192.168.1.1, len 57,
dispose ip.hopcount
.Jul 16 13:53:32.592 beijing: UDP src=47949, dst=53
.Jul 16 13:53:32.592 beijing: IP: s=172.23.9.36 (Vlan52), d=192.168.1.1, len 57,
dispose ip.hopcount
.Jul 16 13:53:32.592 beijing: UDP src=41505, dst=53
.Jul 16 13:53:32.592 beijing: IP: s=10.3.2.101 (Vlan52), d=192.168.1.1, len 57,
dispose ip.hopcount
.Jul 16 13:53:32.592 beijing: UDP src=48699, dst=53
.Jul 16 13:53:32.592 beijing: IP: s=172.23.144.52 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:32.592 beijing: IP: s=192.168.28.16 (Vlan28), d=192.168.28.255, le
.Jul 16 13:53:32.592 beijing: UDP src=137, dst=137
.Jul 16 13:53:32.592 beijing: IP: s=10.105.14.104 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:32.592 beijing: UDP src=56498, dst=53
.Jul 16 13:53:32.592 beijing: IP: s=10.104.125.104 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:32.592 beijing: UDP src=46150, dst=53
.Jul 16 13:53:32.592 beijing: IP: s=192.168.22.15 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:32.592 beijing: IP: s=192.168.22.43 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:32.601 beijing: UDP src=137, dst=137
.Jul 16 13:53:32.601 beijing: IP: s=192.168.22.15 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:32.601 beijing: IP: s=192.168.21.86 (Vlan21), d=192.168.21.255, le
.Jul 16 13:53:32.601 beijing: IP: s=192.168.28.16 (Vlan28), d=224.0.0.252, len 6
.Jul 16 13:53:32.601 beijing: UDP src=59837, dst=5355
.Jul 16 13:53:32.601 beijing: IP: s=192.168.22.15 (Vlan22), d=224.0.0.252, len 5
.Jul 16 13:53:32.601 beijing: UDP src=50275, dst=5355
.Jul 16 13:53:32.601 beijing: UDP src=62107, dst=5355
.Jul 16 13:53:32.601 beijing: UDP src=59598, dst=5355
.Jul 16 13:53:32.609 beijing: IP: s=192.168.22.15 (Vlan22), d=224.0.0.252, len 5
.Jul 16 13:53:32.609 beijing: UDP src=62107, dst=5355
.Jul 16 13:53:32.609 beijing: IP: s=172.23.128.2 (Vlan100), d=224.0.0.18, len 40
.Jul 16 13:53:32.668 beijing: IP: s=192.168.28.16 (Vlan28), d=192.168.28.255, le
.Jul 16 13:53:32.668 beijing: UDP src=137, dst=137
.Jul 16 13:53:32.718 beijing: IP: s=10.6.63.103 (Vlan52), d=192.168.1.1, len 57,
dispose ip.hopcount
.Jul 16 13:53:32.718 beijing: UDP src=33960, dst=53
.Jul 16 13:53:33.011 beijing: IP: s=10.101.99.102 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:33.011 beijing: UDP src=59027, dst=53
.Jul 16 13:53:33.011 beijing: IP: s=10.103.134.101 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:33.019 beijing: UDP src=43255, dst=53
.Jul 16 13:53:33.019 beijing: IP: s=172.23.88.116 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:33.019 beijing: UDP src=60509, dst=53
.Jul 16 13:53:33.078 beijing: IP: s=192.168.22.15 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:33.078 beijing: UDP src=137, dst=137
.Jul 16 13:53:33.078 beijing: IP: s=192.168.22.43 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:34.124 beijing: IP: s=192.168.22.15 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:34.124 beijing: UDP src=137, dst=137
.Jul 16 13:53:34.250 beijing: IP: s=192.168.22.15 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:34.250 beijing: UDP src=137, dst=137
.Jul 16 13:53:34.250 beijing: IP: s=192.168.21.86 (Vlan21), d=192.168.21.255, le
.Jul 16 13:53:34.258 beijing: IP: s=10.105.36.100 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:34.258 beijing: UDP src=56448, dst=53
.Jul 16 13:53:34.258 beijing: IP: s=10.104.143.105 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:34.258 beijing: UDP src=55871, dst=53
.Jul 16 13:53:34.258 beijing: IP: s=10.104.28.103 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:34.258 beijing: UDP src=35269, dst=53
.Jul 16 13:53:34.258 beijing: IP: s=10.104.32.101 (Vlan52), d=192.168.1.1, len 5
.Jul 16 13:53:34.258 beijing: UDP src=49089, dst=53
.Jul 16 13:53:34.258 beijing: IP: s=10.5.43.103 (Vlan52), d=192.168.1.1, len 57,
dispose ip.hopcount
.Jul 16 13:53:34.258 beijing: UDP src=44567, dst=53
.Jul 16 13:53:34.258 beijing: IP: s=192.168.23.110 (Vlan23), d=192.168.23.255, l
en 211, dispose udp.noport
.Jul 16 13:53:34.258 beijing: UDP src=138, dst=138
.Jul 16 13:53:34.258 beijing: IP: s=10.100.173.102 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:34.258 beijing: UDP src=35121, dst=53
.Jul 16 13:53:34.258 beijing: IP: s=192.168.21.86 (Vlan21), d=192.168.21.255, le
.Jul 16 13:53:34.267 beijing: UDP src=137, dst=137
.Jul 16 13:53:34.267 beijing: IP: s=192.168.28.16 (Vlan28), d=192.168.28.255, le
.Jul 16 13:53:34.267 beijing: IP: s=192.168.21.186 (Vlan21), d=192.168.21.255, l
.Jul 16 13:53:34.267 beijing: IP: s=10.104.114.103 (Vlan52), d=192.168.1.1, len
.Jul 16 13:53:34.267 beijing: UDP src=38601, dst=53
.Jul 16 13:53:34.267 beijing: IP: s=192.168.22.15 (Vlan22), d=192.168.22.255, le
.Jul 16 13:53:34.267 beijing: IP: s=192.168.21.86 (Vlan21), d=192.168.21.255, le
.Jul 16 13:53:34.275 beijing: IP: s=192.168.23.17 (Vlan23), d=192.168.23.255, le
n 222, dispose udp.noport
.Jul 16 13:53:34.275 beijing: UDP src=138, dst=138
.Jul 16 13:53:34.275 beijing: IP: s=172.23.128.2 (Vlan100), d=224.0.0.18, len 40
.Jul 16 13:53:34.275 beijing: IP: s=192.168.22.43 (Vlan22), d=224.0.0.252, len 6
.Jul 16 13:53:34.275 beijing: UDP src=52369, dst=5355
.Jul 16 13:53:34.275 beijing: IP: s=192.168.28.16 (Vlan28), d=224.0.0.252, len 6
.Jul 16 13:53:34.275 beijing: UDP src=64296, dst=5355
Mansur
你这个错误包真多,看看具体在哪个接口下
show interface | i error
show interface xxxxx
然后再具体排查吧。这种错误一般跟配置没关系,多半是主机上的问题
5201314wdmcwfnh
79 unknown protocol, 23 ...
查了。都是0
在接口下面没有看出哪个接口有大道的错误。
这个跟接口错误没有太大关系吧? bad hop count ,这意思是不是下一点地址不正确啊?
Rockyw
bad hop count这一般是由于TTL过期导致的,如果每隔几秒都有大量计数增加,很明显,网络中存在routing loop
Rockyw | If it solves your problem, please mark as answer. Thanks !
快捷链接
