取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
话机8861如何手工从3PCC刷成SIP版本?
lifenglu50789
目前有一台8861,目前版本是3PCC的10.0的版本,请问如何手工从TFTP刷机到SIP版本呢?
似乎和以前7975方法不同的
求助!感谢!
2 条回复2
fayawang
我找到的一个关于upgrade的介绍是英文版的希望对你有帮助。但我没有实际测试过。
Firstly, let’s read the user’s question: “I might have missed something in the documentation but I spent a lot of time trying to upgrade my 3PCC phones to Enterprise.
This is why I wanted to share it with you in a simple task list:
1. download from CCO a 8800 firmware. .zip format, not .cop.sgn.
2. unzip the files and share it with a TFTP server. I used a third party TFTP server and the CUCM too, both works.
3. connect to the phone using the following URL: http:///admin/advanced
4. click on Voice tab and Provisioning.
5. in Upgrade Rule field, put tftp:////.loads (exemple: tftp://1.1.1.1/sip88xx.10-3-1-20.loads)
6. for Enable Enterprise Image Upgrade, select Yes.
7. check if the Firmware upgrade is at it's default value (Yes) and click on Submit All Changes.
Yanli Sun
Community Manager
Community Manager
感谢专家解答
快捷链接
