取消
显示结果
搜索替代
您的意思是:
查看次数
8
有帮助
7
回复
cisco mcu4515
shipinweixiu
如何给Cisco 4515mcu通过串口来恢复出厂设置
1 个已接受解答
已接受的解答
yaoyang
To return your unit to its factory settings and reset the password:
Connect a serial terminal to your unit's console port using the settings given on the back panel label.
Reboot the unit and watch the output on the serial terminal. After a few seconds you will see the message 'Cisco TelePresence MCU 8510 4.2(0.36) (Build 6.17(0.36)) starting' or similar.
Type reset_config and press Enter. (Type reset_password and press Enter if using an IP Gateway. Note this command can be used at any point, not just when the unit is rebooting, and no settings except the admin password details will be restored.)
Type yes or y and press Enter. The unit will now reboot again.
When bootup is complete, type status on the serial terminal to see the IP address that the unit has acquired using DHCP. Alternatively, set a static IP address on port A using the static command.
Connect to the web interface of the unit and log in using 'admin' and no password. A warning message on the web page banner will tell you that a product activation key is required.
Go to Settings > Upgrade and enter the unit's activation keys. After the activation keys are applied, you will be able to use your unit again.
记得先保存license key
在原帖中查看解决方案
7 条回复7
yaoyang
记得先保存license key
你的回答很有效果哦~恭喜您获得20社区金钱!
one-time
Level 13
Level 13
感谢您的提问,期待小伙伴的回复!
sh666666
Level 10
Level 10
用串口线连接设备。重启设备,看到 'Cisco TelePresence MCU 8510 4.2(0.36) (Build 6.17(0.36)) starting' 时,输入reset_config 并回车,如是IP网关,输入reset_password 并回车。输入YES或Y,并回车。设备将再次重启。设备重启完成后,输入status查看DHCP分配的IP 地址。也可为PORT A 分配一个静态的IP地址。连接设备的WEB口,用admin和空密码登入设备,会被提示需要一个产品激活KEY。去到Settings > Upgrade ,并输入产品激活KEY。在应用了产品激活KEY后,你又能使用该设备了。记得先保存license key!!!!
fortune
连接串行终端到您的单元的控制台端口使用在Back面板标签给的设置。
重新启动单元并且观看在串行终端的输出。在一些秒钟之后您将看到消息‘Codian MCU 8510 4.2(0.36) (构建6.17(0.36))开始’或类似。
键入reset_config并且按回车。
键入是或y并且按回车。
单元再当前将重新启动。
当启动完成时,请键入在串行终端的状态发现使用DHCP,单元获取了的IP地址。或者,使用static命令,设置在端口A的一个静态IP地址。
使用‘admin’和没有密码,连接对单元的Web接口并且登陆。在网页标语的一个警告消息将告诉您产品激活密钥要求。
去设置>升级并且输入单元的激活密钥。在激活密钥应用后,您能再使用您的单元。
要更改密码,请去用户。
这个看看
非常感谢您的回答,您获得的社区20金钱已为您发放!
快捷链接
