取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
6
回复
FXO端口一直处于off-hook
tony_tan
各位专家你们好,请教各位两个语音方面的问题:1.公司的2911上注册了一部7821和两个7945G话机,最近网络电话呼外线一直无法呼出,可以打进来,但挂了电话过一会电话就会响一下,拿起话筒没有任何声音. 使用show voice port summary,voice-port 0/0/0端口一直处理off-hook ,其它都是on-hook.2.内部分机不显示外线的来电号码,只显示Unknow number.请各位指点,谢谢!
CISCO2911_Router#sh voice port su
IN OUT
PORT CH SIG-TYPE ADMIN OPER STATUS STATUS EC
0/0/0 -- fxo-ls up up idle off-hook y
0/0/1 -- fxo-ls up dorm idle on-hook y
0/0/2 -- fxo-ls up dorm idle on-hook y
0/0/3 -- fxo-ls down down idle on-hook y
50/0/1 1 efxs up dorm on-hook idle y
50/0/2 1 efxs up up on-hook idle y
PWR FAILOVER PORT PSTN FAILOVER PORT
CISCO2911_Router#sh dial-peer voice sum
dial-peer hunt 0
AD PRE PASS SESS-SER-GRP\ OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT PORT KEEPALIVE VRF
1 pots up up .T 0 up 0/0/0 NA
5 pots up up 8006 0 up 0/0/0 NA
10 pots up up 8007 0 up 0/0/1 NA
15 pots up up 8008 0 up 0/0/2 NA
20001 pots up up 8008$ 0 50/0/1 NA
20002 pots up up 8007$ 0 50/0/2 NA
40001 voip up up 8006$ 0 syst ipv4:192.168.10.49:5 NA
For server-grp details please execute command:show voice classserver-group
To see complete session target for ipv6 use 'sh running config | section dial-peer
6 条回复6
tony_tan
语音配置:
voice service voip
no ip address trusted authenticate
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
no supplementary-service h450.2
no supplementary-service h450.3
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
sip
registrar server expires max 3600 min 120
voice class dualtone-detect-params 1
freq-max-deviation 25
cadence-variation 15
voice class custom-cptone Disconnect
dualtone disconnect
frequency 465
cadence 356 356
voice register global
mode cme
source-address 172.16.88.253 port 5060
timeouts interdigit 3
max-dn 20
max-pool 10
load 7821 sip78xx.11-5-1-18
authenticate register
timezone 42
time-format 24
tftp-path flash:
file text
create profile sync 0002014006170219
auto-register
voice register dn 3
number 8006
call-forward b2bua busy 2007
call-forward b2bua noan 2007 timeout 10
allow watch
pickup-group 2
name Tony
label Tony Tan
voice register pool 1
busy-trigger-per-button 2
id mac 80E8.6F23.8274
type 7821
number 1 dn 3
dtmf-relay sip-notify
username 8006 password cisco
codec g711ulaw
voice translation-rule 1
rule 1 /^5736\(8...\)$/ /\1/
voice translation-rule 2
rule 2 // /8008/
voice translation-rule 3
rule 1 /^.*$/ /9\0/
voice translation-profile from-pstn
translate calling 1
translate called 1
vxml logging-tag
license udi pid CISCO2911/K9 sn FTX1538AMME
hw-module pvdm 0/0
tftp-server flash:SCCP45.8-5-3S.loads
tftp-server flash:cnu45.8-5-3TH1-6.sbn
tftp-server flash:term45.default.loads
tftp-server flash:cvm45sccp.8-5-3TH1-6.sbn
tftp-server flash:term65.default.loads
tftp-server flash:dsp45.8-5-3TH1-6.sbn
tftp-server flash:jar45sccp.8-5-3TH1-6.sbn
tftp-server flash:apps45.8-5-3TH1-6.sbn
tftp-server flash:sboot78xx.11-5-1-18.sbn
tftp-server flash:sboot2.78xx.11-5-1-18.sbn
tftp-server flash:rootfs78xx.11-5-1-18.sbn
tftp-server flash:rootfs2.78xx.11-5-1-18.sbn
tftp-server flash:kern78xx.11-5-1-18.sbn
tftp-server flash:kern2.78xx.11-5-1-18.sbn
tftp-server flash:sip78xx.11-5-1-18.loads
control-plane
voice-port 0/0/0
translation-profile incoming from-pstn
supervisory disconnect dualtone mid-call
input gain -6
output attenuation -6
cptone CN
timeouts call-disconnect 1
timeouts ringing 15
timeouts wait-release 1
connection plar opx 8006
description PBX_206 FXO
caller-id enable
caller-id mode DTMF
caller-id alerting ring 2
voice-port 0/0/1
cptone CN
timeouts ringing 15
connection plar opx 8007
description PBX_207 FXO
caller-id enable
caller-id mode DTMF
voice-port 0/0/2
cptone CN
timeouts ringing 15
connection plar opx 8008
description PBX_208 FXO
caller-id enable
caller-id mode DTMF
voice-port 0/0/3
cptone CN
timeouts ringing 15
connection plar 1
shutdown
description ***** Connect to CTCC *****
caller-id enable
caller-id mode DTMF
dial-peer voice 1 pots
description ***** Connect to PBX EXT108 *****
destination-pattern .T
direct-inward-dial
port 0/0/0
dial-peer voice 5 pots
destination-pattern 8006
port 0/0/0
dial-peer voice 10 pots
destination-pattern 8007
port 0/0/1
dial-peer voice 15 pots
destination-pattern 8008
port 0/0/2
gatekeeper
shutdown
telephony-service
max-ephones 16
max-dn 32
ip source-address 172.16.88.253 port 2000
system message Sailnet.LTD
load 7945 cvm45sccp.8-5-3TH1-6
time-zone 42
time-format 24
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp 7960 May 03 2020 12:21:56
ephone-dn 1
number 8008
label GUIYUAN
call-forward busy 8006
call-forward noan 8006 timeout 10
ephone-dn 2
number 8007
pickup-group 1
label Shi Yongzheng
name Operator
ephone 1
device-security-mode none
mac-address B4E9.B08D.E3B7
keepalive 10
username "Alixe Tan"
type 7945
button 1:1
ephone 2
mac-address E8BA.7007.1F2E
keepalive 10
type 7945
button 1:2
tony_tan
无人解答,这个问题是个案吗?
tony_tan
等待高手出现.....
vengarboy
0/0/0 端口off-hook的问题,可以先判断下物理线路是否正常,直接连接一台模拟电话,测试下。没有号码显示,你可以先测试下你的translation-profile,正常情况下来说,从PSTN入向的呼叫,是不需要对主叫方做号码转换的,最多加个出局号码,共回拨使用。
tony_tan
vengarboy_cisco 发表于 2020-5-18 14:55
0/0/0 端口off-hook的问题,可以先判断下物理线路是否正常,直接连接一台模拟电话,测试下。没有号码显示, ...
接模拟电话都是正常的
tony_tan
已经解决,感谢artsgroup李工远程协助
快捷链接
