取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
C9800 stuck in boot
Bill lo
Hi all
設備:C9800-L-F  在一次重啟後就不能正常開機:
Chassis 1 reloading, reason - Critical process crash
Mar 2 11:53:17.358: %PMAN-5-EXITACTIvp: Process manager is exiting:
Mar 2 11:54:30.396: %PMAN-5-EXITACTION: F0/0: pvp: Process manager is exiting:
Mar 2 11:54:48.078: %PMAN-0-PROCESS_NOTIFICATION: R0/0: pvp: The process lifecycle notification component failed because Processes Shutdown Timeout
甚至也無法進入ROMMON
請問有人遇到相同狀況嗎?
4 条回复4
ilay
看log是因为process crash导致的重启,还有process shutdown timeout的异常,尝试重新加电呢?
如果不行还是直接找TAC吧,crash的问题普通用户不太好排查解决
Hi ilay
感謝你的回覆,由於該產品沒有服務合同,所以無法開立Case支持。
由於該設備沒有服務合同,所以無法請求TAC支援;
thx
Bill
该问题的确比较负责,看到有类似的案例,也都是建议如下 :
1、 - Push reset button for more then 10 seconds (have a factory reset), upgrade to last advisory release first : https://software.cisco.com/download/home/286323158/type/282046477/release, then restore the configuration from backup.
2、
Do not use 17.3.1.  Use a more recent version, like 17.3.5b.
Force the WLC to boot into ROMMON and then use "emergency-install" to put a newer firmware into the WLC.
3、If you have TAC support, pls reach out to them & see how you can recover.
refer to:如上的内容从如下链接中copy
https://community.cisco.com/t5/wireless/c9800-wlc-reboot-continuously-and-enter-rommon-mode-fail/td-p/4668079
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
Hi  Rps-Cheers
感謝你的回覆,
1/有試過,但設備還是不斷加載。
2/無法中斷開機程序進入ROMMON mode
3/目前暫時無法開立Case
thx
Bill
快捷链接
