取消
显示结果
搜索替代
您的意思是:
查看次数
有帮助
回复
SNTP(24X7X4) of Smart Net Total Care, what means for "P"?
zulachung
3 个已接受解答
已接受的解答
balaji.bandi
SNTP means this appliance is under coverage for support for 3 years. SNT = SMARTnet and P stands for Premium. This ONLY includes the device and any software that comes on it by default such as the iOS version. Additional software add-ons are not included in this.
24x7x4 translates to the replacement time window for that unit. This device will be replaced within a 4-hour window at any time during its coverage period.
OS means Onsite. This means a qualified engineer will deliver the device, swap it out and put a config on the device (if supplied by customer). There is a cost premium for the Onsite aspect of it so be aware of the use case.
BB
在原帖中查看解决方案
Cisco SMARTnet acronym key
Acronym Definition
SNT SMARTnet
SNTP SMARTnet Premium
24x7x4 4-hour hardware replacement at any time
OS On Site
SWSS Software Support Service
Rps-Cheers | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
Rockyw
What do those Cisco support part numbers mean?
SNTSMARTnet Support 8x5xNBD
SNTESMARTnet Support 8x5x4
SNTPSMARTnet Support 24x7x4
S2PSMARTnet Support 24x7x2
CSOnsite SMARTnet Support 8x5xNBD
C4SOnsite SMARTnet Support 8x5x4
C4POnsite SMARTnet Support 24x7x4
C2POnsite SMARTnet Support 24x7x2
SAUSoftware app support + upgrade
SASSoftware app support
SUSWIPS Signatures and Software
SU1IPS Service 8x5xNBD
SU2IPS Service 8x5x4
SU3IPS Service 24x7x4
SU4IPS Service 24x7x2
SUO1IPS Onsite 8x5xNBD
SUO2IPS Onsite 8x5x4
SUO3IPS Onsite 24x7x4
SUO4IPS Onsite 24x7x2
What does SNTP 24x7x4 OS mean?
A common misconception from customers is that they believe if they are covered by SWSS (Software Support Service) they do not need to worry about SMARTnet. It’s crucial to know that SWSS applies to software only. SWSS allows you to upgrade to the newest version of that software and call up Cisco TAC (Technical Assistance Center) or help with related issues during the time of coverage.
However, SWSS does not cover the device! If you only have SWSS on an existing device and that device fails, you will not be eligible for a replacement. You can only get a replacement with an SNT or SNTP contract.
Acronym Definition
SNTSMARTnet
SNTPSMARTnet Premium
24x7x44-hour hardware replacement at any time
OSOn Site
SWSSSoftware Support Service
Features of SMARTnet
Benefits of SMARTnet
Rockyw | If it solves your problem, please mark as answer. Thanks !
在原帖中查看解决方案
3 条回复3
balaji.bandi
BB
Acronym Definition
SNT SMARTnet
OS On Site
Rockyw
Acronym Definition
SNTSMARTnet
OSOn Site
快捷链接
