날짜: 03-07-2024 02:49 PM
Hello.
The following log consistently occurs on the 3850 switch:
Is this a bug?
What will be the impact on the system?
Please give me a solution.
%IOSXE-3-PLATFORM: Switch 1 R0/0: kernel: SQUASHFS error: Unable to read fragment cache entry [4efb7e]
%IOSXE-3-PLATFORM: Switch 1 R0/0: kernel: SQUASHFS error: Unable to read page, block 4efb7e, size 13cbc
thank you
날짜: 03-07-2024 05:21 PM
when are you getting that error while upgrading ?
check the space and remove unwanted file from flash and test it.
what IOS code running ?
날짜: 03-07-2024 05:44 PM
Thank you for answer.
The iOS currently in use is Version 16.6.4.
This log occurred during an operation, not during an upgrade.
This log repeats at least 4 times per second.
Feb 28 2024 13:57:02: %IOSXE-3-PLATFORM: Switch 1 R0/0: kernel: SQUASHFS error: Unable to read fragment cache entry [4efb7e]
Feb 28 2024 13:57:02: %IOSXE-3-PLATFORM: Switch 1 R0/0: kernel: SQUASHFS error: Unable to read page, block 4efb7e, size 13cbc
Feb 28 2024 13:57:03: %IOSXE-3-PLATFORM: Switch 1 R0/0: kernel: SQUASHFS error: Unable to read fragment cache entry [4efb7e]
Feb 28 2024 13:57:03: %IOSXE-3-PLATFORM: Switch 1 R0/0: kernel: SQUASHFS error: Unable to read page, block 4efb7e, size 13cbc
Feb 28 2024 13:57:04: %IOSXE-3-PLATFORM: Switch 1 R0/0: kernel: SQUASHFS error: Unable to read fragment cache entry [4efb7e]
Feb 28 2024 13:57:04: %IOSXE-3-PLATFORM: Switch 1 R0/0: kernel: SQUASHFS error: Unable to read page, block 4efb7e, size 13cbc
dir flash: for information
7650 -rw- 2097152 Dec 22 2021 10:17:49 +09:00 nvram_config
7652 -rw- 76 Jul 29 2021 22:29:07 +09:00 boothelper.log
30598 -rw- 19167872 Jul 29 2021 22:25:40 +09:00 cat3k_caa-guestshell.16.06.04.SPA.pkg
30602 -rw- 27905983 Jul 29 2021 22:25:42 +09:00 cat3k_caa-rpbase.16.06.04.SPA.pkg
30599 -rw- 331879032 Jul 29 2021 22:25:41 +09:00 cat3k_caa-rpcore.16.06.04.SPA.pkg
30601 -rw- 15676032 Jul 29 2021 22:25:41 +09:00 cat3k_caa-srdriver.16.06.04.SPA.pkg
7654 -rw- 4742 Jul 29 2021 22:26:25 +09:00 packages.conf
7658 drwx 4096 Jul 29 2021 22:29:05 +09:00 dc_profile_dir
7660 -rw- 128103 Jul 29 2021 22:29:22 +09:00 memleak.tcl
7669 drwx 4096 Aug 19 2020 06:45:10 +09:00 core
7657 -rw- 185 Jul 29 2021 22:28:54 +09:00 bootloader_evt_handle.log
15298 drwx 4096 Aug 19 2020 06:31:54 +09:00 .prst_sync
30594 drwx 4096 Aug 19 2020 06:31:55 +09:00 .rollback_timer
7671 drwx 4096 Aug 19 2020 06:32:01 +09:00 gs_script
7673 drwx 4096 Jul 29 2021 22:28:32 +09:00 .installer
7674 -rw- 2097152 Dec 22 2021 10:17:50 +09:00 nvram_config_bkup
7676 -rw- 676 Oct 20 2021 22:03:40 +09:00 vlan.dat
30600 -rw- 16251516 Jul 29 2021 22:25:41 +09:00 cat3k_caa-webui.16.06.04.SPA.pkg
1,602,994,176 bytes total (1,103,024,128 bytes free)
Flash space appears to be sufficient.
새로운 아이디어를 발견하고 저장하세요. 전문가 답변, 단계별 가이드, 최근 주제 등 다양한 내용을 확인해 보세요.
처음이신가요? 아래 팁들을 확인해 보세요. 시스코 커뮤니티 사용하기 새 멤버 가이드
