취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
Cisco DNA Center Installation Guide
gunheon103
When installing Cisco DNA Center, is there a case where the DNA Center equipment GUI is not accessible after the installation process is finished without a cluster interface?
1 채택된 솔루션
채택된 솔루션
Make sure what hardware you have and check the version of DNAC you installing.
BB
원본 게시물의 솔루션 보기
4 응답 4
balaji.bandi
is this single DNAC Installation ? hardware or virtual ?
check maglec status of packages ( DNAC take some time to get all the packages install) - make sure you using right interface to connect to DNAC
maglev package status
check installation guide :
https://www.cisco.com/c/en/us/td/docs/cloud-systems-management/network-automation-and-management/dna-center/2-3-5/install_guide/2ndgen/b_cisco_dna_center_install_guide_2_3_5_2ndGen/m_configure_appliance_mcw_2_3_5_2ndgen.html#task_tdr_ltj_sfb
BB
It is hardware and recently installed without requiring a cluster interface, but after the installation was complete, an error appeared in the GUI and was not accessible.
I'm planning to reinstall it later. Thank you.
BB
After installing DNA C, I found that it takes time to access the GUI.
Currently, it can be used right away without a reinstallation process.
빠른 링크
