취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
Nexus 9K show socket connect command Questions
dudgkr
Change the ssh port to use
I checked it with the show socket connection command.
Looks like port 22 is open
Is port 22 open?
If you run a port scan program, I wonder if port 22 will be detected as open.
1 응답 1
balaji.bandi
check on device :
#show ssh server
BB
빠른 링크
