03-30-2022 03:06 AM
I have a quick technical question:
Is it possible to use the Cisco Table Microphone (the omnidrectional round one) with the older Cisco TelePresence MX 300?
It seems to be the same type of connection (3.5mm jack), but i can´t find anything about compatibility since the older model isn´t listed on the compatible devices sheet of the microphone.
Would be glad for a quick answer,
03-30-2022 04:56 AM
If the device is not in the compatibility list, then it's not supported and / or won't work, easy as that.
You can try to connect it anyway and test, if it works. But when you have problems, nobody can help, since it's not supported.
06-13-2022 09:19 PM
The devices are similar, so may likely work, but as the MX300 is an end of support device, they are not supported. I have not personally tested on an old MX300, but I have previously used them on SX20 and MX300G2 codecs without any issues.
You would need the CS-MIC-TABLE-J= version and not the CS-MIC-TABLE-E= which has a different connector.
Please remember to mark helpful responses and to set your question as answered if appropriate.
