Jabber 12.9.x | Headsets call control breaks when "Mute all sounds when in a meeting" is selected
rodmarcos
Hello all
A client of mine has found a Cisco Jabber bug where you break headset call control when you select "Mute all sounds when in a meeting" on Settings->Notifications.
This works fine on 12.8.x. It seems to be affecting 12.9.x.
Plantronics and Jabra headsets tested.
Scenario:
1) Receive a call on Jabber
2) Headset flashes when Jabber is ringing and I can pick up the call with the headset button
3) Select "Mute all sounds when in a meeting".
4) Exit Cisco Jabber-> crucial step
5) Re-Open Cisco Jabber
6) Receive a call on Jabber
7) Headset no longer flashes when the call is ringing and I'm not able to pick up the call with the headset button
Headset: Jabra Evolve 40 UC Stereo
Firmware: 3.10.0 and 4.1.0 (latest)
OS: Windows 10 Enterprise Version 1909 Build 18363.1379
Jabber: 12.9.1 and 12.9.3
Jaime Valencia
Open a TAC to have this looked at.
java
if this helps, please rate
Thanks Jaime
I did, just wanted to see if anyone else was aware about it.
rodmarcos
mat_herrmann
I can confirm this bug and reproduce it (using a Jabra Headset, Evolve 2 65).
Analyzing the fulldump leads to the same result as stated in this bug-report: https://community.cisco.com/t5/collaboration-applications/jabber-12-9-5-55511-crashs-probably-related-to-jabra-headset/td-p/4411889
I attach the console view of the fulldump analysis just for information.
