Linksys WVC200 and WVC210 in Chrome and Edge
Andreas K.
In Internet Explorer after downloading the add-on "PlayerPT Control" and "Cisco210Viewer Control", the images on the Linksys WVC200 and WVC210 cameras could be seen without any problems.
What kind of solution is there for Chrome and Edge in order to be able to enjoy these cameras as well as in IE?
Many thanks for the help,
Andreas
Andreas K.
Hi there Kasun,
Thank you for the IE tab idea.
After adding the IE-Tab application to Chrome and Edge as extension and installing the necessary ietabhelper.exe, the images appear in both browsers from the two Linksys IP PTZ cameras WVC200 and WVC210.
But, you can operate in the IE-Tab only the WVC200.
The free IE-Tab app is by no means a hundred percent solution, but until something better doesn't come up, you have to live with it.
KR,
Andreas
i did not tested this in your scenario. but try IE simulation in chrome with below extension.
https://chrome.google.com/webstore/detail/ie-tab/hehijbfgiekmjfkfjpbkbammjbdenadd
rate and mark as answer if this solved your concern
Good luck
KB
Andreas K.
Hi there Kasun,
KR,
Andreas
I am looking for firmware for wvc210
