VoIP Phone 8845 Bleutooth Headset and wired Headset at the same time
schmil
I'm using a bluetooth headset connected directly to the Cisco 8845. Works fine.
But I have a second wirded headset connected to the RJ12 port in the back. This doesn't work. Is the BT-headset prioritized and switches of the wired one or do I have to configure something?
you can use only one headset at a time.AFAIK  When you connect multiple headsets to your phone, you can choose the primary audio device to use for a call. The below guide is for MPP, i don't have a phone to test the below with Enterprise version. Try the below.
https://www.cisco.com/c/en/us/support/docs/smb/collaboration-endpoints/cisco-ip-phone-8800-series/smb5624-configure-a-bluetooth-device-on-a-cisco-ip-phone-8800-series.html
Response Signature
