Changing Default Phone Numbers on Invitiation
jedhhtx
Greetings, Webex-Community,
I use Webex Meetings in Germany. When I send an invitation, the default phone numbers to call in are always in the UK, but I am sure that my old (accidental) free account had an option to set the phone numbers to use.
I seem to have found where to do that in Settings/Audio and Video/Standard Dial-up Numbers (my apologies if the nomenclature is wrong; I have the German website). The problem is that the numbers do not get saved if I click on Save, so the next invitation has UK again...
I would very much appreciate any help or suggestions you might have!
Take care,
Jed
Hello Ashish,
I've got the same Problem then Jed. Unfortunately there is no Default call-in number - Menu.
In the solution is this "Note: If this section is missing, this feature hasn't been enabled by the administrator."
So my question is, where can I enable this feature?
I looked through the menues, but I didn't find the possibilty to enable it...
Thanks a lot,
Alex
Thank you, Ashish!
That was exactly what I needed. :-)
Cheers,
Jed
