07-18-2021 07:17 AM
How do I change video resolution for my web camera?
Solved! Go to Solution.
07-19-2021 08:35 AM
If you go into Webex settings, select your camera under the video tab, and you'll see a checkbox for "Enable HD." If you un-check that box, that will lower the video resolution to 480p standard definition.
07-19-2021 08:35 AM
07-19-2021 09:09 AM
Thank you
