Where is webex.deb for linux?
daititt@msn.com
I can't find it on Downloads.
https://www.webex.com/downloads.html is the web site. If you scroll down to Other Download Options, Other Operating Systems you can select Linux .deb or Linus .rpm
daititt@msn.com
Thank you, Ipersing! That worked fine. It downloaded, installed and opened fine.
Mysteriously, the url you gave me is the same url I tried unsuccessfully a dozen times before.
lpersing
I had the same problem when I was installing Webex on Mint. I ran sudo apt-get install ./Webex.deb from the terminal and it installed. This was after I had downloaded it from webex.com
Thanks, but my problem is that I can't download webex.deb.  I can't find it anywhere. It's not in https://www.webex.com/downloads.html/
Where did you find it, Ipersing?
