Device Management Portal - using asp.net & c#
lmd1004
Hello!
I am implementing the portal using asp.net and c#. I have the AD authentication set up working but would like to see some web form examples with the code behind for the login.aspx signRequest and verifyResponse methods. What the web.config looks like as well?
Thanks for any help!
DuoKristina
Hello there! Hvae you taken a look at our WebSDK demo for ASP?
Duo, not DUO.
lmd1004
Yes, but what I’m looking is an actual example of a working implementation with the secondary Duo authentication. I’d really like to see how this is working, what responses to expect and how to handle. Thanks!
