Difference between status and result in the response body
In the response for duo auth api’s /auth end point
“stat”: “OK”,
“response”: {
“result”: “allow”,
“status”: “allow”,
“status_msg”: “Success. Logging you in…”
What are the purposes of status and result elements?
DuoKristina
Hello there! These are described right in the AuthAPI documentation.
Duo, not DUO.
DuoKristina
Duo, not DUO.
