ACI, 2 BD´s and 2 EPGs in L2 mode won´t talk even with contract supplied
odahlqvist
Level 4
Level 4
Hi experts
I tried to make a L2 connection between 2 EPG in different BD, both BD are in L2 mode and in the same Private network, I saw in the sniffer that the traffic was send between the EPG ( hosts)  but the "ping" between the hosts did not got answered. we had a contract between the EPG´s that was allow any in both directions.
the connection works between the 2 host  with the  2 EPG´s  in the same BD with the same any contract.
is it intended that 2 BDS won´t let 2 EPG´s talk in L2 mode ( Floodmode ) ?.
And I read that the L2 external is not a separate BD but 2 EPG´s  in a " L2 construct"  with a contract between and the AEP stuff to get physical to work
/Ola
dpita
Just to understand, you created two BDs in flood and L2 mode and two EPGs. The two hosts are using the same subnet/address space to talk to each other and you have a contract in between the two EPGs yet the communication is not working.
When you put the two EPGs in the same BD it works? correct?
Its a very interesting question, but there is something you must remember about ACI. The BD is the flood/forwarding boundary. Since you are using two different flood domains and no routing (unicast off and no subnet/SVI on the BD), ARPs and general data flood/packets will not traverse the flood domains, even with a contract.
What other questions do you have? Thanks for using Support Forums, hope that helps!
It is absolutely correct that answered by dpita. To add on this for the communication between these two EPGs in different BDs, You can use any layer 2 device or firewall as a bridge outside the fabric to extend the EPGs and make them bridge to communicate.
This is more or less the current workaround for the micro-segmentation in ACI :)
Anser
