Using the 9508 as both a leaf and spine switch?
ericbkchng
I have a question: Do the modular N9K switches, such as the 9508, support a mixture of leaf and spine line cards in the same chassis (i.e. function as both a leaf and spine)?
The online documents seem to suggest that the switches can only function as either a spine OR a leaf under ACI mode, but I wanted to be sure.
Thanks!
Robert Correiro
Hey ericbkchng,
As of right now, the 9500 model is not supported as a leaf node, and can only function as a spine. You're correct in assuming that switches can only function as either a leaf OR a spine.
Hope this helps.
Robert Correiro
Hey ericbkchng,
Hope this helps.
