ACI 2 Factor Authentication with DUO
bill.greenwood
Is it possible to configure two factor authentication for the APIC?  If so can someone provide me a link to the documentation.
11 Replies 11
Robert Burns
Bill,
2factor auth isn't supported yet.   It's coming out with ACI 4.0 which is doing out in a couple months tentatively.
Robert
Hi all
I can read in the slides from Barcelona that the 2 factor authentication should be possible now, also with Google Authenticator. Does someone has a link to a document which tells me how this can be configured in ACI 4.0?
Thank you
Markus
Duo is not supported.  You can find some details on the feature in the Security Guide:  https://www.cisco.com/c/en/us/td/docs/switches/datacenter/aci/apic/sw/2-x/Security_config/b_Cisco_APIC_Security_Configuration_Guide.html
Robert
Hi Robert
Thank you for your reply. I also found this document, but it applies to the release 3.x and earlier. Does such as a document also exists for the release 4.x? And what is with the Google Authenticator, would that one work instead of the Duo?
The jpg I referred to Barcelona I attached it here, so based on this there should be a 2 factor authentication be possible since the release 3.x?
Thank you
Markus
I haven't heard much on Google Auth myself, but let me chase both these items up and get back to you.  Might need a couple days as the US is on holiday today, but I'll update this thread as soon as I have details.
Robert
Hi Robert
I just want to ask if you got any feedback from the tech guys about the 2nd factor authentication and if this would be possible with Goolge Authenticator or then another product?
Thank you
Markus
Dear Robert
Did you already got a feedback from the tech guys regarding this dual factor authentication option with DUO for ACI?
Thank you
Markus
Markus,
This is tentatively targeted for the 4.2 release before the end of the year.  If anything changes, I'll update the thread.
Robert
Thanks Robert for this helpful information. I then will wait for the new release.
Thank you
Markus
I recognize this is an old thread but does anyone know if Duo and ACI are compatible and, if so, is there any documentation for how to set that up? Our finance department uses Electronic Bill Presentment and Payment (ebppcsi.aciworldwide.com) and ACI is now requiring MFA. We already have a DUO environment and would like to use that if possible.
yes it looks like starting with ACI 5, DUO is supported for two-factor authentication.
Cisco APIC Security Configuration Guide, Release 5.0(x) - TACACs+, RADIUS, LDAP, RSA, SAML, and DUO [Cisco Application Policy Infrastructure Controller (APIC)] - Cisco
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
