ACI and MP BGP
visitor68
Level 5
Level 5
Hi, folks...
Someone emailed me this question and left me totally confused. Can someone make sense out of this question for me? Wondering if my whole understanding of ACI is lacking...
"When I build a fabric using Nexus is the control plane an either/or situation?
If ACI is my control plane then I don’t use BGP EVPN as control plane and vice versa?
If I still can use BGP EVPN as control plane with ACI do I lose ACI features?"
Sergiu.Daniluk
Hi @visitor68
The question itself is confusing. ACI is a solution, while BGP EVPN is a protocol.
Nexus can run NXOS (stanadlone mode) or iNXOS (ACI mode) as operating systems.
In NXOS mode, you can build VXLAN fabrics with MP-BGP EVPN as a control plane protocol which provides protocol-based VTEP peer discovery and end-host reachability information distribution
In ACI mode, the solution is using many protocols as 'control plane': IS-IS - for routing, VXLAN - for traffic tunneling, MP-BGP VPNv4 - for external route exchange, MP-BGP EVPN - for multi-pod/,multi-site endpoints exchange, COOP for EP control in local pod.
Hope it helps..
Stay safe,
Sergiu
Sergiu.Daniluk
Hi @visitor68
Hope it helps..
Stay safe,
Sergiu
Sergiu! How are you, my friend? Thanks ofr the quick answer. Yes, I agree with everything. I don't understand his question. He makes it sound like he wants to run a Nexus environment with an ACI controller.
If ACI is my control plane then I don’t use BGP EVPN as control plane and vice versa?"
I guess neither one of us could understand what he means here. LOL
Hellooo V. :-)
A bit swamped these days, but overall doing good. I hope you are safe and healthy as well.
"If ACI is my control plane" - yep. Most likely the confusion is, as you mentioned, that the person believes that "ACI" can be used on-demand for controlling the Nexus switches.
Anyway, I am sure you will be able to help him out to clear the confusion and have a better understanding of the ACI :-)
Take care,
Sergiu
